Change Webhook timeout
Hello, is it possible to set the timeout in which a webhook must be answered before it is requested again?
Sometimes answering the webhook takes a little longer, and then Zammad sends the webhook to the endpoint several times, so that the webhook is then also executed several times.
Currently, it’s not possible to change the timeout time. There is an open timeout of 30 seconds configured.
