- Used Zammad version: 5.2.x
- Used Zammad installation type: (source, package, docker-compose, …)package
- Operating system: Ubuntu 20.04.4 LTS
- Browser + version: Brave [Version 1.42.97 Chromium: 104.0.5112.102], Microsoft Edge (Version 104.0.1293.63)
after updating ubuntu and renewing the ssl certificate, the login should work as usual
LDAP synchronization works, but you cannot log in with these users. The following error appears:
“Sign-in failed. Have you checked your sign-in details and completed the email verification step?”
LDAP synchronization reports: failed tcp bind → USERLOGIN
“Can’t connect to ldap backend Invalid filter syntax.”
My SSL certificate has expired, so I wanted to renew it. In this context, UBUNTU reported me some update (20.04.2 LTS → 20.04.4 LTS). And also Zammad, Elastics etc., so I launched these updates.
After the updates the login didn’t work anymore. I keep getting the above error.
here the production.log
I, [2022-08-26T07:55:49.727211 #799-110900] INFO -- : ended Channel.fetch took: 0.362394446 seconds.
I, [2022-08-26T07:55:49.739082 #777-109420] INFO -- : Completed 200 OK in 54ms (Views: 30.4ms | ActiveRecord: 7.5ms | Allocations: 33202)
I, [2022-08-26T07:55:54.679314 #777-109360] INFO -- : Started GET "/api/v1/integration/ldap/job_start?_=1661491728010" for 10.255.255.13 at 2022-08-26 07:55:54 +0200
I, [2022-08-26T07:55:54.688633 #777-109360] INFO -- : Processing by Integration::LdapController#job_start_index as JSON
I, [2022-08-26T07:55:54.688729 #777-109360] INFO -- : Parameters: {"_"=>"1661491728010"}
I, [2022-08-26T07:55:54.720577 #777-109360] INFO -- : Completed 200 OK in 32ms (Views: 0.4ms | ActiveRecord: 16.1ms | Allocations: 6262)
I, [2022-08-26T07:55:58.106852 #799-108940] INFO -- : Running job thread for 'Check channels.' (Channel.fetch) status is: sleep
I, [2022-08-26T07:56:00.675605 #777-108920] INFO -- : Started GET "/api/v1/integration/ldap/job_start?_=1661491728011" for 10.255.255.13 at 2022-08-26 07:56:00 +0200
I, [2022-08-26T07:56:00.686617 #777-108920] INFO -- : Processing by Integration::LdapController#job_start_index as JSON
I, [2022-08-26T07:56:00.686717 #777-108920] INFO -- : Parameters: {"_"=>"1661491728011"}
I, [2022-08-26T07:56:00.717367 #777-108920] INFO -- : Completed 200 OK in 31ms (Views: 0.4ms | ActiveRecord: 13.4ms | Allocations: 6262)
I, [2022-08-26T07:56:06.675060 #777-109660] INFO -- : Started GET "/api/v1/integration/ldap/job_start?_=1661491728012" for 10.255.255.13 at 2022-08-26 07:56:06 +0200
I, [2022-08-26T07:56:06.684878 #777-109660] INFO -- : Processing by Integration::LdapController#job_start_index as JSON
I, [2022-08-26T07:56:06.684955 #777-109660] INFO -- : Parameters: {"_"=>"1661491728012"}
I, [2022-08-26T07:56:06.716503 #777-109660] INFO -- : Completed 200 OK in 31ms (Views: 0.4ms | ActiveRecord: 16.4ms | Allocations: 6262)
I, [2022-08-26T07:56:10.689607 #777-112400] INFO -- : Started GET "/api/v1/http_logs/ldap?limit=50&_=1661491728013" for 10.255.255.13 at 2022-08-26 07:56:10 +0200
I, [2022-08-26T07:56:10.701530 #777-112400] INFO -- : Processing by HttpLogsController#index as JSON
I, [2022-08-26T07:56:10.701681 #777-112400] INFO -- : Parameters: {"limit"=>"50", "_"=>"1661491728013", "facility"=>"ldap"}
I, [2022-08-26T07:56:10.752823 #777-112400] INFO -- : Completed 200 OK in 51ms (Views: 28.9ms | ActiveRecord: 7.2ms | Allocations: 33199)
I, [2022-08-26T07:56:12.685105 #777-109420] INFO -- : Started GET "/api/v1/integration/ldap/job_start?_=1661491728014" for 10.255.255.13 at 2022-08-26 07:56:12 +0200
I, [2022-08-26T07:56:12.694201 #777-109420] INFO -- : Processing by Integration::LdapController#job_start_index as JSON
I, [2022-08-26T07:56:12.694323 #777-109420] INFO -- : Parameters: {"_"=>"1661491728014"}
I, [2022-08-26T07:56:12.726727 #777-109420] INFO -- : Completed 200 OK in 32ms (Views: 0.5ms | ActiveRecord: 15.7ms | Allocations: 6265)
I, [2022-08-26T07:56:18.097114 #799-193160] INFO -- : execute Job.run (try_count 0)...
I, [2022-08-26T07:56:18.099449 #799-193160] INFO -- : ended Job.run took: 0.007642715 seconds.
I, [2022-08-26T07:56:18.681189 #777-109360] INFO -- : Started GET "/api/v1/integration/ldap/job_start?_=1661491728015" for 10.255.255.13 at 2022-08-26 07:56:18 +0200
I, [2022-08-26T07:56:18.690582 #777-109360] INFO -- : Processing by Integration::LdapController#job_start_index as JSON
I, [2022-08-26T07:56:18.690691 #777-109360] INFO -- : Parameters: {"_"=>"1661491728015"}
I, [2022-08-26T07:56:18.722270 #777-109360] INFO -- : Completed 200 OK in 31ms (Views: 0.6ms | ActiveRecord: 15.1ms | Allocations: 6262)
I, [2022-08-26T07:56:19.731689 #799-110900] INFO -- : execute Channel.fetch (try_count 0)...
I, [2022-08-26T07:56:19.734216 #799-110900] INFO -- : fetching imap (owa.tutuuuuu.com/tutuuuu\it-support port=993,ssl=true,starttls=false,folder=INBOX,keep_on_server=false,auth_type=LOGIN)
I, [2022-08-26T07:56:20.027332 #799-110900] INFO -- : - no message
I, [2022-08-26T07:56:20.039236 #799-110900] INFO -- : ended Channel.fetch took: 0.310624872 seconds.
I, [2022-08-26T07:56:24.681035 #777-108920] INFO -- : Started GET "/api/v1/integration/ldap/job_start?_=1661491728016" for 10.255.255.13 at 2022-08-26 07:56:24 +0200
I, [2022-08-26T07:56:24.690403 #777-108920] INFO -- : Processing by Integration::LdapController#job_start_index as JSON
I, [2022-08-26T07:56:24.690525 #777-108920] INFO -- : Parameters: {"_"=>"1661491728016"}
I, [2022-08-26T07:56:24.721967 #777-108920] INFO -- : Completed 200 OK in 31ms (Views: 0.4ms | ActiveRecord: 15.6ms | Allocations: 6262)
