- Used Zammad version: 5.0.3
- Operating system: Debian Stretch
- Browser + version:
- I have to rebuild the index, because it was build with ES 5.x, to update ES to version 7
- Running
gave me the error “Version 6.8.21 of configured elasticsearch is not supported.” Below is the output from the command:
** Execute environment
** Invoke searchindex:configured (first_time)
** Execute searchindex:configured
rake aborted!
/opt/zammad/lib/search_index_backend.rb:29:in info' /opt/zammad/lib/search_index_backend.rb:1065:in
version’
/opt/zammad/lib/search_index_backend.rb:1075:in version_int' /opt/zammad/lib/search_index_backend.rb:1085:in
version_supported?’
/opt/zammad/lib/tasks/search_index_es.rake:69:in block (2 levels) in <main>' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in
block in execute’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in each' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in
execute’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:219:in block in invoke_with_call_chain' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in
synchronize’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in invoke_with_call_chain' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:243:in
block in invoke_prerequisites’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:241:in each' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:241:in
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:218:in block in invoke_with_call_chain' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in
synchronize’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in invoke_with_call_chain' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:188:in
invoke’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:160:in invoke_task' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in
block (2 levels) in top_level’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in each' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in
block in top_level’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:125:in run_with_threads' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:110:in
top_level’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:83:in block in run' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:186:in
standard_exception_handling’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:80:in run' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/exe/rake:27:in
<top (required)>’
/opt/zammad/vendor/bundle/ruby/2.7.0/bin/rake:23:in load' /opt/zammad/vendor/bundle/ruby/2.7.0/bin/rake:23:in
<top (required)>’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/cli/exec.rb:63:in load' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/cli/exec.rb:63:in
kernel_load’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/cli/exec.rb:28:in run' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/cli.rb:494:in
exec’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/vendor/thor/lib/thor/command.rb:27:in run' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in
invoke_command’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/vendor/thor/lib/thor.rb:392:in dispatch' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/cli.rb:30:in
dispatch’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/vendor/thor/lib/thor/base.rb:485:in start' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/cli.rb:24:in
start’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/exe/bundle:49:in block in <top (required)>' /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/friendly_errors.rb:130:in
with_friendly_errors’
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/exe/bundle:37:in <top (required)>' /opt/zammad/bin/bundle:5:in
load’
/opt/zammad/bin/bundle:5:in `’
Tasks: TOP => searchindex:rebuild => searchindex:version_supported
In the search_index_backend.rb there is a comment “# only versions greater/equal than 6.5.0 are supported”, but this doesn’t seem to work. I Have tried to install several ES Version up from 6.5, but the error is every time the same.
