Background tasks issues
  • Used Zammad version: 6.3.1-1722007696.43d58aa5.bookworm
  • Used Zammad installation type: DEB
  • Operating system: Debian 12
  • Browser + version: various
Email should be fectched, and overview refreshed
It works, then crash email are not fetched anymore, need to push F5 to refresh overview…
Restart psql + zammad fix it for a time.
No idea !
More infos
16GB RAM
4Core
20 users connected
No delayed job count
WEB_CONCURRENCY = 3
ZAMMAD_PROCESS_SCHEDULED_JOBS_WORKERS = 1
ZAMMAD_SESSION_JOBS_CONCURRENT = 2
Kind of error I get on postgresql:
2024-10-10 11:11:53.887 CEST [15218] zammad@zammad DÉTAIL: Reason code: Canceled on identification as a pivot, during write.
2024-10-10 11:11:53.887 CEST [15218] zammad@zammad ASTUCE : La transaction pourrait réussir après une nouvelle tentative.
2024-10-10 11:11:53.887 CEST [15218] zammad@zammad INSTRUCTION : INSERT INTO “active_job_locks” (“lock_key”, “active_job_id”, “created_at”, “updated_at”) >
2024-10-10 11:11:53.903 CEST [15218] zammad@zammad ERREUR: la transaction est annulée, les commandes sont ignorées jusqu’à la fin du bloc
de la transaction
Kind of error I get on production.log:
E, [2024-10-10T11:16:29.416716#15056-276280] ERROR – : thread_client 159820 exited with error #<ActiveRecord::ConnectionTimeoutError: could not obtain a connection from the pool within 5.000 seconds (waited 5.011 seconds); all pooled connections were in use>
E, [2024-10-10T11:16:29.432035#15056-276280] ERROR – : /opt/zammad/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.4/lib/active_record/connection_adapters/abstract/connection_pool/queue.rb:126:in block in wait_poll' E, [2024-10-10T11:16:40.428430#15056-276820] ERROR -- : thread_client 160340 exited with error #<ActiveRecord::ConnectionTimeoutError: could not obtain a connection from the pool within 5.000 seconds (waited 5.709 seconds); all pooled connections were in use> E, [2024-10-10T11:16:40.756711#15056-276820] ERROR -- : /opt/zammad/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.4/lib/active_record/connection_adapters/abstract/connection_pool/queue.rb:126:in block in wait_poll’
E, [2024-10-10T11:16:46.052683#15056-276280] ERROR – : thread_client 159820 exited with error #<ActiveRecord::ConnectionTimeoutError: could not obtain a connection from the pool within 5.000 seconds (waited 5.306 seconds); all pooled connections were in use>
E, [2024-10-10T11:16:46.075358#15056-276280] ERROR – : /opt/zammad/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.4/lib/active_record/connection_adapters/abstract/connection_pool/queue.rb:126:in block in wait_poll' E, [2024-10-10T11:16:56.757050#15056-276820] ERROR -- : thread_client 160340 exited with error #<ActiveRecord::ConnectionTimeoutError: could not obtain a connection from the pool within 5.000 seconds (waited 5.336 seconds); all pooled connections were in use> E, [2024-10-10T11:16:56.757147#15056-276820] ERROR -- : /opt/zammad/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.4/lib/active_record/connection_adapters/abstract/connection_pool/queue.rb:126:in block in wait_poll’
E, [2024-10-10T11:17:03.084059#15056-276280] ERROR – : thread_client 159820 exited with error #<ActiveRecord::ConnectionTimeoutError: could not obtain a connection from the pool within 5.000 seconds (waited 6.302 seconds); all pooled connections were in use>
E, [2024-10-10T11:17:03.107326#15056-276280] ERROR – : /opt/zammad/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.4/lib/active_record/connection_adapters/abstract/connection_pool/queue.rb:126:in block in wait_poll' E, [2024-10-10T11:17:12.231083#15056-276820] ERROR -- : thread_client 160340 exited with error #<ActiveRecord::ConnectionTimeoutError: could not obtain a connection from the pool within 5.000 seconds (waited 5.278 seconds); all pooled connections were in use> E, [2024-10-10T11:17:12.246635#15056-276820] ERROR -- : /opt/zammad/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.4/lib/active_record/connection_adapters/abstract/connection_pool/queue.rb:126:in block in wait_poll’
E, [2024-10-10T11:17:19.732028#15056-276280] ERROR – : thread_client 159820 exited with error #<ActiveRecord::ConnectionTimeoutError: could not obtain a connection from the pool within 5.000 seconds (waited 5.698 seconds); all pooled connections were in use>
E, [2024-10-10T11:17:19.753217#15056-276280] ERROR – : /opt/zammad/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.4/lib/active_record/connection_adapters/abstract/connection_pool/queue.rb:126:in block in wait_poll' E, [2024-10-10T11:17:28.069654#15056-276820] ERROR -- : thread_client 160340 exited with error #<ActiveRecord::ConnectionTimeoutError: could not obtain a connection from the pool within 5.000 seconds (waited 5.459 seconds); all pooled connections were in use> E, [2024-10-10T11:17:28.069767#15056-276820] ERROR -- : /opt/zammad/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.4/lib/active_record/connection_adapters/abstract/connection_pool/queue.rb:126:in block in wait_poll’
E, [2024-10-10T11:17:36.325619#15056-276280] ERROR – : thread_client 159820 exited with error #<ActiveRecord::ConnectionTimeoutError: could not obtain a connection from the pool within 5.000 seconds (waited 5.577 seconds); all pooled connections were in use>
E, [2024-10-10T11:17:37.344109#15056-276280] ERROR – : /opt/zammad/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.4/lib/active_record/connection_adapters/abstract/connection_pool/queue.rb:126:in `block in wait_poll’
Let me know if you need more infos…
Many thanks !
Sounds like your concurrency is higher than that you configured.
Hello, thanks for answering !
You mean WEB_CONCURRENCY ? It like that since years now, and no issues before.
And as I see, the value in database.yaml cannot be changed (it as no effect)…
Apparently the errors you get on PostgreSQL side are unrelated to those on the zammad side, since the timestamps do not match and zammad is claiming it cannot obtain a connection, while PostgreSQL is claiming the transaction has to be aborted.
I think that when the problem rises, restarting only zammad should fix the issue, can you verify?
I still believe that the problem is saying that PostgreSQL is busy, but I don’t know exactly how activerecord pooling works.
I thought also the same, the error are unrelated.
I’ll try next time it happen to restart only Zammad…
And I also agree that the error suggest that PostgreSQL is busy when I get the error. But no idea why, and also no idea why it cause trouble on the email fetching and overview refresh…
Zammad by default (without any tuning) takes up to 200 database connections, while PostgreSQL by default allows 100 only.
This is reflected as a note / hint by our installation documentation, here’s the relevant part that solves your problem:
https://docs.zammad.org/en/latest/appendix/configure-env-vars.html
