Hi @fliebe92, of course I can provide further information about one example automation.
There exists tickets for hardware. Every Tuesday morning ad 8:20 there should be send mails for those tickets, to remind the user, that they can pick up there hardware.
Abstract from log:
I, [2024-02-28T13:42:19.147313#1540986-142000] INFO -- : ProcessScheduledJobs running...
I, [2024-02-28T13:42:19.148093#1540986-142000] INFO -- : Running job thread for 'Process ticket escalations.' (Ticket.process_escalation) status is: sleep
I, [2024-02-28T13:42:19.148115#1540986-142000] INFO -- : Running job thread for 'Check channels.' (Channel.fetch) status is: sleep
I, [2024-02-28T13:42:19.148195#1540986-142000] INFO -- : Running job thread for 'Generate 'Session' data.' (Sessions.jobs) status is: sleep
I, [2024-02-28T13:42:19.148218#1540986-142000] INFO -- : Running job thread for 'Check 'Channel' streams.' (Channel.stream) status is: sleep
I, [2024-02-28T13:42:19.238188#555-45971860] INFO -- : Completed 200 OK in 257ms (Views: 17.0ms | ActiveRecord: 17.9ms | Allocations: 136262)
I, [2024-02-28T13:42:19.332675#555-46472820] INFO -- : Started GET "/api/v1/tickets/17637?all=true&auto_assign=true&_=1709122325471" for 172.17.90.11 at 2024-02-28 13:42:19 +0100
I, [2024-02-28T13:42:19.335372#555-46472820] INFO -- : Processing by TicketsController#show as JSON
I, [2024-02-28T13:42:19.335394#555-46472820] INFO -- : Parameters: {"all"=>"true", "auto_assign"=>"true", "_"=>"1709122325471", "id"=>"17637"}
I, [2024-02-28T13:42:19.419617#555-46472820] INFO -- : Completed 200 OK in 84ms (Views: 17.4ms | ActiveRecord: 10.4ms | Allocations: 103612)
I, [2024-02-28T13:42:19.758960#555-46634200] INFO -- : Started GET "/api/v1/tickets/17885?all=true&auto_assign=true&_=1709122325472" for 172.17.90.11 at 2024-02-28 13:42:19 +0100
I, [2024-02-28T13:42:19.761497#555-46634200] INFO -- : Processing by TicketsController#show as JSON
I, [2024-02-28T13:42:19.761519#555-46634200] INFO -- : Parameters: {"all"=>"true", "auto_assign"=>"true", "_"=>"1709122325472", "id"=>"17885"}
I, [2024-02-28T13:42:19.828896#555-46634200] INFO -- : Completed 200 OK in 67ms (Views: 6.6ms | ActiveRecord: 10.4ms | Allocations: 94749)
I, [2024-02-28T13:42:22.126204#555-45976560] INFO -- : Started PUT "/api/v1/jobs/29" for 172.17.90.43 at 2024-02-28 13:42:22 +0100
I, [2024-02-28T13:42:22.128948#555-45976560] INFO -- : Processing by JobsController#update as JSON
I, [2024-02-28T13:42:22.128996#555-45976560] INFO -- : Parameters: {"name"=>"Abholbereite Sachen - Erinnerungen losschicken", "object"=>"Ticket", "timeplan"=>{"days"=>{"Mon"=>false, "Tue"=>true, "Wed"=>false, "Thu"=>false, "Fri"=>false, "Sat"=>false, "Sun"=>false}, "hours"=>{"0"=>false, "1"=>false, "2"=>false, "3"=>false, "4"=>false, "5"=>false, "6"=>false, "7"=>false, "8"=>true, "9"=>false, "10"=>false, "11"=>false, "12"=>false, "13"=>false, "14"=>false, "15"=>false, "16"=>false, "17"=>false, "18"=>false, "19"=>false, "20"=>false, "21"=>false, "22"=>false, "23"=>false}, "minutes"=>{"0"=>false, "10"=>false, "20"=>true, "30"=>false, "40"=>false, "50"=>false}}, "condition"=>{"ticket.state_id"=>{"operator"=>"is not", "value"=>["4"]}, "ticket.title"=>{"operator"=>"contains", "value"=>"--abholbereit"}}, "perform"=>{"notification.email"=>{"body"=>"[FILTERED]", "internal"=>"false", "recipient"=>["ticket_customer"], "subject"=>"[IT-Support] Für dich liegt etwas zur Abholung bereit!", "include_attachments"=>"false"}}, "disable_notification"=>true, "note"=>"", "active"=>true, "id"=>"29"}
I, [2024-02-28T13:42:22.131521#555-46562400] INFO -- : Started GET "/api/v1/jobs?full=true&page=1&per_page=150&sort_by=name,%20id&order_by=ASC,%20ASC&_=1709101817075" for 172.17.90.43 at 2024-02-28 13:42:22 +0100
I, [2024-02-28T13:42:22.134991#555-46562400] INFO -- : Processing by JobsController#index as JSON
I, [2024-02-28T13:42:22.135244#555-46562400] INFO -- : Parameters: {"full"=>"true", "page"=>"1", "per_page"=>"150", "sort_by"=>"name, id", "order_by"=>"ASC, ASC", "_"=>"1709101817075"}
I, [2024-02-28T13:42:22.160746#555-46472640] INFO -- : Started GET "/api/v1/tickets/13608?all=true&auto_assign=true&_=1708931509079" for 172.24.100.165 at 2024-02-28 13:42:22 +0100
I, [2024-02-28T13:42:22.304041#555-46472640] INFO -- : Processing by TicketsController#show as JSON
I, [2024-02-28T13:42:22.304468#555-46472640] INFO -- : Parameters: {"all"=>"true", "auto_assign"=>"true", "_"=>"1708931509079", "id"=>"13608"}
I, [2024-02-28T13:42:22.305143#555-46562860] INFO -- : Started GET "/api/v1/tickets/17719?all=true&auto_assign=true&_=1708931509082" for 172.24.100.165 at 2024-02-28 13:42:22 +0100
I, [2024-02-28T13:42:22.310567#555-46562860] INFO -- : Processing by TicketsController#show as JSON
I, [2024-02-28T13:42:22.311035#555-46562860] INFO -- : Parameters: {"all"=>"true", "auto_assign"=>"true", "_"=>"1708931509082", "id"=>"17719"}
I, [2024-02-28T13:42:22.312736#555-46472780] INFO -- : Started GET "/api/v1/tickets/14130?all=true&auto_assign=true&_=1708931509081" for 172.24.100.165 at 2024-02-28 13:42:22 +0100
I, [2024-02-28T13:42:22.317009#555-46562360] INFO -- : Started GET "/api/v1/tickets/14074?all=true&auto_assign=true&_=1708931509080" for 172.24.100.165 at 2024-02-28 13:42:22 +0100
I, [2024-02-28T13:42:22.319645#555-46472780] INFO -- : Processing by TicketsController#show as JSON
I, [2024-02-28T13:42:22.320240#555-46472780] INFO -- : Parameters: {"all"=>"true", "auto_assign"=>"true", "_"=>"1708931509081", "id"=>"14130"}
Other automation will change after two weeks priority from 1 to 2.
Abstract from log:
I, [2024-02-28T13:42:29.151205#1540986-142000] INFO -- : Running job thread for 'Process ticket escalations.' (Ticket.process_escalation) status is: sleep
I, [2024-02-28T13:42:29.151226#1540986-142000] INFO -- : Running job thread for 'Check channels.' (Channel.fetch) status is: sleep
I, [2024-02-28T13:42:29.154259#1540986-1666640] INFO -- : execute Ticket.process_auto_unassign (try_count 0)...
I, [2024-02-28T13:42:29.155499#1540986-1666640] INFO -- : ended Ticket.process_auto_unassign took: 0.003806716 seconds.
I, [2024-02-28T13:42:30.074108#555-46634200] INFO -- : Started PUT "/api/v1/jobs/30" for 172.17.90.43 at 2024-02-28 13:42:30 +0100
I, [2024-02-28T13:42:30.076884#555-46634200] INFO -- : Processing by JobsController#update as JSON
I, [2024-02-28T13:42:30.076937#555-46634200] INFO -- : Parameters: {"name"=>"Clone: Prio 1 Tickets nach 3 Wochen auf Prio 2 setzen", "object"=>"Ticket", "timeplan"=>{"days"=>{"Mon"=>true, "Tue"=>true, "Wed"=>true, "Thu"=>true, "Fri"=>true, "Sat"=>true, "Sun"=>true}, "hours"=>{"0"=>false, "1"=>false, "2"=>false, "3"=>false, "4"=>false, "5"=>false, "6"=>false, "7"=>false, "8"=>false, "9"=>false, "10"=>false, "11"=>false, "12"=>false, "13"=>false, "14"=>true, "15"=>false, "16"=>false, "17"=>false, "18"=>false, "19"=>false, "20"=>false, "21"=>false, "22"=>false, "23"=>false}, "minutes"=>{"0"=>false, "10"=>true, "20"=>false, "30"=>false, "40"=>false, "50"=>false}}, "condition"=>{"ticket.state_id"=>{"operator"=>"is", "value"=>["8", "1", "2"]}, "ticket.priority_id"=>{"operator"=>"is", "value"=>["1"]}, "ticket.updated_at"=>{"operator"=>"before (relative)", "value"=>"3", "range"=>"week"}, "ticket.owner_id"=>{"operator"=>"is", "pre_condition"=>"not_set", "value"=>[], "value_completion"=>""}, "ticket.group_id"=>{"operator"=>"is", "value"=>["2", "9"], "value_completion"=>""}}, "perform"=>{"article.note"=>{"body"=>"[FILTERED]", "internal"=>"true", "subject"=>"Priorität 1 -> 2"}, "ticket.priority_id"=>{"value"=>"2"}}, "disable_notification"=>false, "note"=>"Priorität nach 3 Wochen automatisch erhöht.", "active"=>true, "id"=>"30"}
I, [2024-02-28T13:42:30.079745#555-46562400] INFO -- : Started GET "/api/v1/jobs?full=true&page=1&per_page=150&sort_by=name,%20id&order_by=ASC,%20ASC&_=1709101817079" for 172.17.90.43 at 2024-02-28 13:42:30 +0100
I, [2024-02-28T13:42:30.083733#555-46562400] INFO -- : Processing by JobsController#index as JSON
I, [2024-02-28T13:42:30.083758#555-46562400] INFO -- : Parameters: {"full"=>"true", "page"=>"1", "per_page"=>"150", "sort_by"=>"name, id", "order_by"=>"ASC, ASC", "_"=>"1709101817079"}
I, [2024-02-28T13:42:30.136679#555-46562400] INFO -- : Completed 200 OK in 53ms (Views: 5.2ms | ActiveRecord: 17.5ms | Allocations: 60757)
I, [2024-02-28T13:42:30.138319#555-46634200] INFO -- : Completed 200 OK in 61ms (Views: 0.3ms | ActiveRecord: 16.1ms | Allocations: 68479)
I, [2024-02-28T13:42:30.149820#555-46562860] INFO -- : Started GET "/api/v1/jobs?full=true&page=1&per_page=150&sort_by=name,%20id&order_by=ASC,%20ASC&_=1709101817080" for 172.17.90.43 at 2024-02-28 13:42:30 +0100
I, [2024-02-28T13:42:30.151494#1540986-142000] INFO -- : Running job thread for 'Generate 'Session' data.' (Sessions.jobs) status is: sleep
I, [2024-02-28T13:42:30.151606#1540986-142000] INFO -- : Running job thread for 'Check 'Channel' streams.' (Channel.stream) status is: sleep
I, [2024-02-28T13:42:30.152171#555-46562860] INFO -- : Processing by JobsController#index as JSON
I, [2024-02-28T13:42:30.152194#555-46562860] INFO -- : Parameters: {"full"=>"true", "page"=>"1", "per_page"=>"150", "sort_by"=>"name, id", "order_by"=>"ASC, ASC", "_"=>"1709101817080"}
I, [2024-02-28T13:42:30.181651#555-46562860] INFO -- : Completed 200 OK in 29ms (Views: 5.4ms | ActiveRecord: 4.5ms | Allocations: 45370)
I, [2024-02-28T13:42:30.374403#555-46472640] INFO -- : Started POST "/api/v1/knowledge_bases/init" for 172.24.101.51 at 2024-02-28 13:42:30 +0100
I, [2024-02-28T13:42:30.377137#555-46472640] INFO -- : Processing by KnowledgeBasesController#init as JSON
I, [2024-02-28T13:42:30.377163#555-46472640] INFO -- : Parameters: {"answer_translation_content_ids"=>[67, 66, 32]}
I, [2024-02-28T13:42:30.544068#555-46472640] INFO -- : Completed 200 OK in 167ms (Views: 10.6ms | ActiveRecord: 31.4ms | Allocations: 206576)
I, [2024-02-28T13:42:30.567151#555-45976560] INFO -- : Started GET "/api/v1/jobs/?full=true&_=1709101817081" for 172.17.90.43 at 2024-02-28 13:42:30 +0100
I, [2024-02-28T13:42:30.569170#555-45976560] INFO -- : Processing by JobsController#index as JSON
I, [2024-02-28T13:42:30.569190#555-45976560] INFO -- : Parameters: {"full"=>"true", "_"=>"1709101817081"}
I, [2024-02-28T13:42:30.742195#555-45976560] INFO -- : Completed 200 OK in 173ms (Views: 5.3ms | ActiveRecord: 5.1ms | Allocations: 45150)
I, [2024-02-28T13:42:30.749675#555-46472780] INFO -- : Started GET "/api/v1/jobs?full=true&page=1&per_page=150&sort_by=name,%20id&order_by=ASC,%20ASC&_=1709101817082" for 172.17.90.43 at 2024-02-28 13:42:30 +0100
I, [2024-02-28T13:42:30.752068#555-46472780] INFO -- : Processing by JobsController#index as JSON
I, [2024-02-28T13:42:30.752092#555-46472780] INFO -- : Parameters: {"full"=>"true", "page"=>"1", "per_page"=>"150", "sort_by"=>"name, id", "order_by"=>"ASC, ASC", "_"=>"1709101817082"}
I, [2024-02-28T13:42:30.783324#555-46472780] INFO -- : Completed 200 OK in 31ms (Views: 4.8ms | ActiveRecord: 6.1ms | Allocations: 44960)
I, [2024-02-28T13:42:31.773230#555-46562360] INFO -- : Started POST "/api/v1/tickets/selector" for 172.17.90.43 at 2024-02-28 13:42:31 +0100
I, [2024-02-28T13:42:31.775809#555-46562360] INFO -- : Processing by SelectorsController#preview as JSON
I, [2024-02-28T13:42:31.775845#555-46562360] INFO -- : Parameters: {"condition"=>{"ticket.state_id"=>{"operator"=>"is", "value"=>["8", "1", "2"]}, "ticket.priority_id"=>{"operator"=>"is", "value"=>["2"]}, "ticket.updated_at"=>{"operator"=>"before (relative)", "value"=>"2", "range"=>"week"}, "ticket.owner_id"=>{"operator"=>"is", "pre_condition"=>"not_set", "value"=>[], "value_completion"=>""}, "ticket.group_id"=>{"operator"=>"is", "value"=>["2", "9"], "value_completion"=>""}}, "object"=>"tickets"}
I, [2024-02-28T13:42:31.803316#555-46562360] INFO -- : Completed 200 OK in 27ms (Views: 3.5ms | ActiveRecord: 4.8ms | Allocations: 34308)
I, [2024-02-28T13:42:35.055859#555-46472740] INFO -- : Started PUT "/api/v1/jobs/31" for 172.17.90.43 at 2024-02-28 13:42:35 +0100
I, [2024-02-28T13:42:35.058759#555-46472740] INFO -- : Processing by JobsController#update as JSON
I, [2024-02-28T13:42:35.058817#555-46472740] INFO -- : Parameters: {"name"=>"Clone: Prio 2 Tickets nach 3 Wochen auf Prio 3 setzen", "object"=>"Ticket", "timeplan"=>{"days"=>{"Mon"=>true, "Tue"=>true, "Wed"=>true, "Thu"=>true, "Fri"=>true, "Sat"=>true, "Sun"=>true}, "hours"=>{"0"=>false, "1"=>false, "2"=>false, "3"=>false, "4"=>false, "5"=>false, "6"=>false, "7"=>false, "8"=>false, "9"=>false, "10"=>false, "11"=>false, "12"=>false, "13"=>false, "14"=>true, "15"=>false, "16"=>false, "17"=>false, "18"=>false, "19"=>false, "20"=>false, "21"=>false, "22"=>false, "23"=>false}, "minutes"=>{"0"=>false, "10"=>true, "20"=>false, "30"=>false, "40"=>false, "50"=>false}}, "condition"=>{"ticket.state_id"=>{"operator"=>"is", "value"=>["8", "1", "2"]}, "ticket.priority_id"=>{"operator"=>"is", "value"=>["2"]}, "ticket.updated_at"=>{"operator"=>"before (relative)", "value"=>"2", "range"=>"week"}, "ticket.owner_id"=>{"operator"=>"is", "pre_condition"=>"not_set", "value"=>[], "value_completion"=>""}, "ticket.group_id"=>{"operator"=>"is", "value"=>["2", "9"], "value_completion"=>""}}, "perform"=>{"article.note"=>{"body"=>"[FILTERED]", "internal"=>"true", "subject"=>"Priorität 2 -> 3"}, "ticket.priority_id"=>{"value"=>"3"}}, "disable_notification"=>false, "note"=>"Priorität nach 2 Wochen automatisch erhöht.", "active"=>true, "id"=>"31"}
I, [2024-02-28T13:42:35.061100#555-46251940] INFO -- : Started GET "/api/v1/jobs?full=true&page=1&per_page=150&sort_by=name,%20id&order_by=ASC,%20ASC&_=1709101817083" for 172.17.90.43 at 2024-02-28 13:42:35 +0100
I, [2024-02-28T13:42:35.063915#555-46251940] INFO -- : Processing by JobsController#index as JSON
I, [2024-02-28T13:42:35.063962#555-46251940] INFO -- : Parameters: {"full"=>"true", "page"=>"1", "per_page"=>"150", "sort_by"=>"name, id", "order_by"=>"ASC, ASC", "_"=>"1709101817083"}
I, [2024-02-28T13:42:35.105369#555-46251940] INFO -- : Completed 200 OK in 41ms (Views: 4.7ms | ActiveRecord: 11.9ms | Allocations: 59964)
I, [2024-02-28T13:42:35.107843#555-46472740] INFO -- : Completed 200 OK in 49ms (Views: 0.2ms | ActiveRecord: 9.0ms | Allocations: 68782)
I, [2024-02-28T13:42:35.117321#555-46426380] INFO -- : Started GET "/api/v1/jobs?full=true&page=1&per_page=150&sort_by=name,%20id&order_by=ASC,%20ASC&_=1709101817084" for 172.17.90.43 at 2024-02-28 13:42:35 +0100
I, [2024-02-28T13:42:35.119917#555-46426380] INFO -- : Processing by JobsController#index as JSON
I, [2024-02-28T13:42:35.119946#555-46426380] INFO -- : Parameters: {"full"=>"true", "page"=>"1", "per_page"=>"150", "sort_by"=>"name, id", "order_by"=>"ASC, ASC", "_"=>"1709101817084"}
I, [2024-02-28T13:42:35.153970#555-46426380] INFO -- : Completed 200 OK in 34ms (Views: 7.2ms | ActiveRecord: 4.9ms | Allocations: 45362)
I, [2024-02-28T13:42:35.377635#555-46562540] INFO -- : Started GET "/api/v1/jobs/?full=true&_=1709101817085" for 172.17.90.43 at 2024-02-28 13:42:35 +0100
I, [2024-02-28T13:42:35.380548#555-46562540] INFO -- : Processing by JobsController#index as JSON
I, [2024-02-28T13:42:35.380572#555-46562540] INFO -- : Parameters: {"full"=>"true", "_"=>"1709101817085"}
I, [2024-02-28T13:42:35.411234#555-46562540] INFO -- : Completed 200 OK in 31ms (Views: 5.6ms | ActiveRecord: 5.5ms | Allocations: 44954)
For both automation exists tickets in the view. But mails nor priority is changed.
