Automatic anonymization of closed tickets after a retention period
Data protection regulations (GDPR) require that personal data is removed once it is no longer needed. Support tickets contain personal data in many places: customer reference, article bodies (e-mails with names, addresses, signatures), attachments, and the ticket history. At the same time, organizations want to keep the tickets themselves for reporting and statistics (ticket volume, close times, group workload).
Today the only options are to keep everything (non-compliant after the retention period) or to delete tickets entirely (losing all reporting data). There is no middle ground that removes the personal data but keeps the ticket shell.
  • A data protection officer defines a retention period (e.g. tickets closed for more than 400 days must not contain personal data anymore). An audit finds customer e-mail addresses in old tickets — including in the ticket history.
  • A customer requests deletion of their personal data (GDPR right to erasure). Deleting the user record is not enough: their name and e-mail address remain in articles and denormalized history values of all their old tickets. Deleting the tickets instead destroys the statistics for those periods.
  • Zammad’s “Data Privacy” deletion task removes a user including all their tickets — reporting data is lost.
  • There is no scheduled/automatic job that anonymizes tickets based on age or close date.
  • History entries store old values (value_from/value_to) as denormalized plain-text strings; they are not touched by any existing deletion or anonymization mechanism, so personal data survives there even after user deletion.
A built-in, configurable anonymization for closed tickets, e.g. “anonymize tickets X days after closing”, run by the scheduler, which:
  • replaces the ticket customer (and created/updated references of customer users) with the anonymous system user,
  • removes or redacts the ticket articles and their attachments,
  • anonymizes the ticket history completely — including created_by, id_from/id_to and the plain-text value_from/value_to values (e.g. customer changes showing e-mail addresses),
  • keeps the ticket itself (number, group, state, timestamps, tags) so reporting stays intact,
  • optionally deletes customer users that no longer have any non-anonymized tickets, with a per-user “exclude from deletion” flag.
Ticket#10231725
I have the same GDPR retention concern: deleting the user does not remove personal data embedded in articles and ticket history, while deleting tickets loses reporting data. A configurable scheduler job that anonymizes closed tickets after a defined period would provide the missing middle ground, and I am looking forward to seeing whether this can be added. Would a proposed field-by-field anonymization policy and retention interval help move this request forward?
