- Used Zammad version: 6.5.0-1744879538.cc77c631.noble
- Microsoft 365-Graph connected mailboxes
- If a agent close a ticket with a reply in the ticket, the ticket will be closed and the customer with the reply informed. If the customer has a auto reply set in his eMail-Client, this auto reply should be parsed from the ticket system and should re-open the ticket.
- The auto-reply is recived by the ticket-system and appended to the ticket, but the status “closed” is not set to “open”.
- If a User responds with a normal eMail to the ticket-answer, the tickets gets re-opened as expected
Checked Things
I’m not sure, why this is happening.
- In the Group-Config, “Follow-Up possible” is set to “yes”
- Under Channels → Email → Filter, we had a rule “ignore ‘auto reply’” that we disabled
- Under Channels → Email → Settings → Block Notifications, we use the default rule that should not match to an Outlook-Auto-Reply: (mailer-daemon|postmaster|abuse|root|noreply|noreply.+?|no-reply|no-reply.+?)@.+?
Could you have an idea, why the auto-reply from a customer don’t re-open a closed ticket?
We need this feature; some agents communicate with external people for things like invoices and offers. If they send a invoice as a reply to a request and set the ticket to “close”, and the customer is not available (and sends a auto reply), the agents maybe don’t get this information, because the ticket is still closed/green.
Thanks in advance,
Bastian
