Hello, I’ve moved a Zammad Cloud instance to its own Docker container.
PSQL and files are in there. However, I’m having trouble with ElasticSearch not allowing me to search.
- Used Zammad version: 6.5
- Operating system: Ubuntu
- Browser + version: FF
Search in Backend
Logs in Elastic Image:
[2025-06-23T15:35:03,856][INFO ][o.e.x.s.a.RealmsAuthenticator] [d936c4e2b00d] Authentication of [elastic] was terminated by realm [reserved] - failed to authenticate user [elastic]
[2025-06-23T15:35:03,970][INFO ][o.e.x.s.a.RealmsAuthenticator] [d936c4e2b00d] Authentication of [elastic] was terminated by realm [reserved] - failed to authenticate user [elastic]
I’ve set it up in Docker several times before, and everything always worked.
Now, at the end, I just loaded the files and the PSQL as per the instructions. But now the ES is causing problems.
Can anyone tell me more about this?
This Doku: selfhosted-apps-docker/zammad at master · DoTheEvo/selfhosted-apps-docker · GitHub
