is it possible to set the titel from a new ticket, from a costum field from the selected costumer? I don’t find a solution for this problem.
Thx before ![]()
Thx before ![]()
Could you please explain a bit more about your specific use-case and why this can’t be solved by either Postmaster filters or Triggers?
Be aware that new triggers are broken atm. Fix is on the way. Follow this thread
Afterwards the trigger of @7qubit should work.
Thanks @rolfschmidt, i have updated but the problem is still the same. The System don’t enter variables at trigger.
Ah you are right. I also had this wrong in mind. Currently you only can use the placeholders in the subject and body of a trigger action email. Would be a nice enhancement to have placeholders there too tho. sorry
THX @rolfschmidt
Have anybody a other idea to set the title from a ticket by placeholder. Or make a costum field from organisation visibly in Ticket Formular. ![]()
This topic was automatically closed 41 days after the last reply. New replies are no longer allowed.
