Allow connection to Draft Github issues
Github Draft issues is an important part of Github Project module.
A draft issue has a different link from a regular Github issue, and also has a different property structure.
Also - if extending the Github module with this new ability, the module should also detect (using websocket) when the draft issue is converted to a real issue (the link will change).
