AI Ticket Merger
Very old issue on merging macro that could be now elegantly solved with support of AI:
When multiple tickets are open concerning one single topic, there should be a way to batch merge them.
Examples:
  • Monitoring status UP and DOWN rapid fire
  • Actions that trigger auto email related to the same ticket
  • etc.
There is no macro or other way to batch merge multiple tickets at once, but if we can have an AI macro on opening, with the new AI Text Extractor, we can now search for the relative tickets and merge it directly at entrance, avoiding or better said bypassing the need of a batch manual macro tool.
An AI Ticket Merger that can receive a ticket number for instance coming from the AI Text Extractor or any combination that allow the AI to merge the source ticket to the target provided.
Your Zammad environment:
  • Average concurrent agent count: 3
  • Average tickets a day: 30
  • What roles/people are involved: Mainly pure agents
