Used Zammad version: 6.4.1-1733418007.181ec27f.jammy
Operating system: Linux Mint 21.3 Virginia
Browser + version: Chrome 131.0.6778.70
we use Zammad together with Apache2 because of SSO via Kerberos. Every time after system and Zammad upgrade via “apt update && apt upgrade” the system starts nginx instead of apache2.
Each time I have to do the following steps manually
sudo systemctl stop nginx
sudo systemctl disable nginx
sudo systemctl start apache2
sudo systemctl enable apache2
Of course I’s not a big effort, but I would like to avoid it. Where can I change this behaviour?
Should have looked into the postinstall code before answering.
Though weeks on my end.
Any way, the reason an update strikes your back like that without removing nginx (if you prefer apache2) is that our postinstall scripts prefers nginx during the webserver detection and thus, from your POV, starts the wrong web server back online. So much for the reasons.
Well, I think it is good as is, because it will fit most people’s setup. The only alternative method, that comes to my mind, would be to just leave the web servers autostart settings as is, in case apache2 and nginx are both installed on the system.
However, in my case I had just forgotten to remove nginx after implementing SSO. I think this „issue“ will mainly occur in setups like mine.
Maybe it would be useful to just place a small hint in the setup docs for SSO. (Not sure if this is the only part in your docs, where you recommend to switch to apache2).
