First of all many thanks for your help!
As service “web” is not running according to official docker-compose.yml
I ran it against zammad-scheduler (maybe I was wrong)
I got following errors, which at least make me progressing, but any insight to the most effective way to handle it would be much appreciated:
sudo docker compose run --rm zammad-scheduler rails r "Delayed::Job.where(failed_at: nil).each(&:invoke_job)"
WARN[0000] /opt/stacks/zammad/compose.yaml: `version` is obsolete
[+] Creating 3/3
✔ Container zammad-zammad-postgresql-1 Recreated 1.5s
✔ Container zammad-zammad-redis-1 Recreated 1.1s
✔ Container zammad-zammad-memcached-1 Recreated 1.7s
[+] Running 3/3
✔ Container zammad-zammad-postgresql-1 Started 2.0s
✔ Container zammad-zammad-redis-1 Started 2.1s
✔ Container zammad-zammad-memcached-1 Started 1.7s
I, [2025-04-08T22:30:14.243538#1-6640] INFO -- : Using memcached as Rails cache store.
I, [2025-04-08T22:30:14.246348#1-6640] INFO -- : Using the Redis back end for Zammad's web socket session store.
I, [2025-04-08T22:30:14.353040#1-6640] INFO -- : ActionCable is using the redis instance at redis://zammad-redis:6379.
I, [2025-04-08T22:30:21.901560#1-6640] INFO -- : ActionCable is configured to accept requests from (?-mix:https?:\/\/localhost:\d+), https://example.com.
E, [2025-04-08T22:30:37.094126#1-6640] ERROR -- : Unable to process GET request to elasticsearch URL 'http://zammad-elasticsearch:9200/zammad_production_overview/_update_by_query?conflicts=proceed&slices=auto&max_docs=1000'. Check the response and payload for detailed information:
Response:
#<UserAgent::Result:0x00007fc2afc4f508 @success=false, @body="{\"error\":{\"root_cause\":[{\"type\":\"index_not_found_exception\",\"reason\":\"no such index [zammad_production_overview]\",\"resource.type\":\"index_or_alias\",\"resource.id\":\"zammad_production_overview\",\"index_uuid\":\"_na_\",\"index\":\"zammad_production_overview\"}],\"type\":\"index_not_found_exception\",\"reason\":\"no such index [zammad_production_overview]\",\"resource.type\":\"index_or_alias\",\"resource.id\":\"zammad_production_overview\",\"index_uuid\":\"_na_\",\"index\":\"zammad_production_overview\"},\"status\":404}", @data=nil, @code="404", @content_type=nil, @error="No such file http://zammad-elasticsearch:9200/zammad_production_overview/_update_by_query?conflicts=proceed&slices=auto&max_docs=1000, 404!", @header={"x-elastic-product"=>"Elasticsearch", "content-type"=>"application/json", "content-length"=>"485"}>
Payload:
{"script":{"lang":"painless","source":"ctx._source.updated_by=params.updated_by","params":{"updated_by":{"id":8,"organization_id":null,"login":"REDACTED","firstname":"REDACTED","lastname":"REDACTED","email":"REDACTED.REDACTED@example.com","image":null,"image_source":null,"web":"","phone":"","fax":"","mobile":"","department":"","street":"","zip":"","city":"","country":"","address":"","vip":false,"verified":false,"active":true,"note":"","last_login":"2025-04-08T20:27:21.978Z","source":"saml","login_failed":0,"out_of_office":false,"out_of_office_start_at":null,"out_of_office_end_at":null,"out_of_office_replacement_id":null,"preferences":{"locale":"fr-fr","notification_config":{"matrix":{"create":{"criteria":{"owned_by_me":true,"owned_by_nobody":true,"subscribed":true,"no":false},"channel":{"email":true,"online":true}},"update":{"criteria":{"owned_by_me":true,"subscribed":true,"owned_by_nobody":false,"no":false},"channel":{"email":true,"online":true}},"reminder_reached":{"criteria":{"owned_by_me":true,"owned_by_nobody":false,"subscribed":false,"no":false},"channel":{"email":true,"online":true}},"escalation":{"criteria":{"owned_by_me":true,"owned_by_nobody":false,"subscribed":false,"no":false},"channel":{"email":true,"online":true}}}},"intro":true,"tickets_closed":7,"tickets_open":0,"notification_sound":{"file":"Xylo.mp3","enabled":true},"theme":"light","keyboard_shortcuts_clues":true},"updated_by_id":8,"created_by_id":1,"created_at":"2024-04-16T19:44:13.093Z","updated_at":"2025-04-08T20:27:22.136Z","fullname":"REDACTED"}}},"query":{"bool":{"must":[{"term":{"updated_by_id":8}},{"range":{"updated_by.updated_at":{"lt":"2025-04-08T20:27:22.136Z"}}}]}},"sort":{"id":"desc"}}
Payload size: 0M
E, [2025-04-08T22:30:37.130611#1-6640] ERROR -- : Unable to process GET request to elasticsearch URL 'http://zammad-elasticsearch:9200/zammad_production_public_link/_update_by_query?conflicts=proceed&slices=auto&max_docs=1000'. Check the response and payload for detailed information:
Response:
#<UserAgent::Result:0x00007fc2afc4af58 @success=false, @body="{\"error\":{\"root_cause\":[{\"type\":\"index_not_found_exception\",\"reason\":\"no such index [zammad_production_public_link]\",\"resource.type\":\"index_or_alias\",\"resource.id\":\"zammad_production_public_link\",\"index_uuid\":\"_na_\",\"index\":\"zammad_production_public_link\"}],\"type\":\"index_not_found_exception\",\"reason\":\"no such index [zammad_production_public_link]\",\"resource.type\":\"index_or_alias\",\"resource.id\":\"zammad_production_public_link\",\"index_uuid\":\"_na_\",\"index\":\"zammad_production_public_link\"},\"status\":404}", @data=nil, @code="404", @content_type=nil, @error="No such file http://zammad-elasticsearch:9200/zammad_production_public_link/_update_by_query?conflicts=proceed&slices=auto&max_docs=1000, 404!", @header={"x-elastic-product"=>"Elasticsearch", "content-type"=>"application/json", "content-length"=>"503"}>
Payload:
Payload size: 0M
E, [2025-04-08T22:30:37.201085#1-6640] ERROR -- : Unable to process GET request to elasticsearch URL 'http://zammad-elasticsearch:9200/zammad_production_role/_update_by_query?conflicts=proceed&slices=auto&max_docs=1000'. Check the response and payload for detailed information:
Response:
#<UserAgent::Result:0x00007fc2afc45738 @success=false, @body="{\"error\":{\"root_cause\":[{\"type\":\"index_not_found_exception\",\"reason\":\"no such index [zammad_production_role]\",\"resource.type\":\"index_or_alias\",\"resource.id\":\"zammad_production_role\",\"index_uuid\":\"_na_\",\"index\":\"zammad_production_role\"}],\"type\":\"index_not_found_exception\",\"reason\":\"no such index [zammad_production_role]\",\"resource.type\":\"index_or_alias\",\"resource.id\":\"zammad_production_role\",\"index_uuid\":\"_na_\",\"index\":\"zammad_production_role\"},\"status\":404}", @data=nil, @code="404", @content_type=nil, @error="No such file http://zammad-elasticsearch:9200/zammad_production_role/_update_by_query?conflicts=proceed&slices=auto&max_docs=1000, 404!", @header={"x-elastic-product"=>"Elasticsearch", "content-type"=>"application/json", "content-length"=>"461"}>
Payload:
Payload size: 0M
E, [2025-04-08T22:30:37.275991#1-6640] ERROR -- : Unable to process GET request to elasticsearch URL 'http://zammad-elasticsearch:9200/zammad_production_text_module/_update_by_query?conflicts=proceed&slices=auto&max_docs=1000'. Check the response and payload for detailed information:
Response:
#<UserAgent::Result:0x00007fc2afc5f340 @success=false, @body="{\"error\":{\"root_cause\":[{\"type\":\"index_not_found_exception\",\"reason\":\"no such index [zammad_production_text_module]\",\"resource.type\":\"index_or_alias\",\"resource.id\":\"zammad_production_text_module\",\"index_uuid\":\"_na_\",\"index\":\"zammad_production_text_module\"}],\"type\":\"index_not_found_exception\",\"reason\":\"no such index [zammad_production_text_module]\",\"resource.type\":\"index_or_alias\",\"resource.id\":\"zammad_production_text_module\",\"index_uuid\":\"_na_\",\"index\":\"zammad_production_text_module\"},\"status\":404}", @data=nil, @code="404", @content_type=nil, @error="No such file http://zammad-elasticsearch:9200/zammad_production_text_module/_update_by_query?conflicts=proceed&slices=auto&max_docs=1000, 404!", @header={"x-elastic-product"=>"Elasticsearch", "content-type"=>"application/json", "content-length"=>"503"}>
Payload:
Payload size: 0M
Could it be related to my version of Elastisearch? actually running ELASTICSEARCH_VERSION=8.12.0
