After Update to 2.6 i can not see integrations
Important:
  • Used Zammad version: 2.6
  • Used Zammad installation source: (source, package, …) rpm
  • Operating system: centos 7
  • Browser + version: firefox
  • if i open Integration, the window are blank.
    an i can not search for Users
Maybe you could provide more details and or examine your zammad and elasticsearch logfiles
We cannot help you with missing information about database server (plus Version) and elasticsearch version.
I assume that your elasticsearch version is not matching.
elasticsearch 5.6.11-1.noarch
postgresql 9.2.23-3.e17_4
I just updated my Zammad test server to verify the ES version. Everything works fine for me with the following:
You can not search for users but are all users listed in admin → manage → users?
Can you verify that the elasticsearch plugin ingest-attachment is installed?
sudo /usr/share/elasticsearch/bin/elasticsearch-plugin list
And do the log files show any error as I already asked earlier?
Another interesting question would be:
Did you use integrations in Zammad before and if yes, which ones?
Exception in thread “main” java.lang.UnsupportedClassVersionError: org/elasticsearch/plugins/PluginCli : Unsupported major.minor version 52.0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:808)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:442)
at java.net.URLClassLoader.access$100(URLClassLoader.java:64)
at java.net.URLClassLoader$1.run(URLClassLoader.java:354)
at java.net.URLClassLoader$1.run(URLClassLoader.java:348)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:347)
at java.lang.ClassLoader.loadClass(ClassLoader.java:430)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:323)
at java.lang.ClassLoader.loadClass(ClassLoader.java:363)
at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:482)
no because the major problem is this with the user tap
{“error”:“undefined method `last_owner_update_at=’ for #\u003cTicket:0x00005581f64e0a20\u003e\nDid you mean? last_contact_at=”}
if i would change a user
You might want to have a look at https://github.com/elastic/elasticsearch/issues/17584 and verify your installed java version.
But I would try to update the elasticsearch plugin first and rebuild the searchindex:
sudo bin/elasticsearch-plugin remove ingest-attachment
sudo bin/elasticsearch-plugin install ingest-attachment
systemctl restart elasticsearch
This is not a zammad issue, sorry.
The error with java have i fix. the problem with elasticsearch not. I can not find Users or orginisations
i have install elasticsearch 6.x but the problem is not fixed
Elasticsearch 6.x is currently not supported by Zammad as far as I know (tried that some days ago).
Please do use elasticsearch 5.6.x.
You can take a look at this documentation page:
https://docs.zammad.org/en/latest/install-elasticsearch.html
StatusCode: 500
{“error”:“undefined method `last_owner_update_at=’ for #\u003cTicket:0x00007fad403279f0\u003e\nDid you mean? last_contact_at=”}
after i Have install elasticsearch 5.6.x.
Where do you get this error message?
If I’m on tickets change status.
Sorry for the delay.
I assume that zammad already knows your elasticsearch URL.
Did you do a rebuild of the searchindex after reinstall?
