I just check channel loading and it was overloaded. So there was a problem to send network package from server to client. Thats why permanent “Loading” appeared when trying to connect to Zammad page
Hi there! I’m new to the platform and I have the same issue you had with your Zammad installation.
Could you please tell me which stepts did you make to solve the issue with the loading screen?
What do you mean by communication channel?
Hi! It’s not a Zammad problem in my case. It was a hardware problem on network channel side. There was too many packages and thats why there was no way to send the packages from Zammad server to client. After I found the source of the problem and fix the source overwhelmed the connectivity everything start works well.
