I just installed Zammad on Ubuntu 18.04.
Zammad is running, all 4 Services are up.
opening the site “localhost” or also from other machine with the ip-adress, it shows only the standard Ngix-welcome page. Not a page from Zammad.
What could be the problem for this?
In zammad.conf the servername is “zammadsrv”. but on this, nothing is reachable.
Thank you for any help!
Michael
maybe some problem with postgresql, on running postinstallscript, I’ve got this error:
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/pg-0.21.0/lib/pg.rb:56:in `initialize’: could not connect to server: No such file or directory (PG::ConnectionBad)
Is the server running locally and accepting
connections on Unix domain socket “/var/run/postgresql/.s.PGSQL.5432”?
But Postgresql is running…???
Please update your first post to the following template - these information are necessary.
### Infos:
<!-- **Important:**
**If you are a Zammad Support or hosted customer and experience a technical issue, please refer to: support@zammad.com using your zammad-hostname / or company contract.** -->
* Used Zammad version:
* Used Zammad installation source: (source, package, ...)
* Operating system:
* Browser + version:
### Expected behavior:
### Actual behavior:
