After i-doit upgrade integration not works Zammad
ear Support Team,
We recently updated i-doit CMDB to version 25, api 1.14.1, since that i-doit integration does not work - cant add CI from CMDB through Zammad.
The error message what i can see in the admin interface (system>integrations>i-doit)
i-doit system error: Please specify a user by RPC Session header or HTTP Basic Authentication.",“data”:null}}
Was worked with the previous version of i-doit.
  • Used Zammad version: 6.0.0
  • Operating system: Ubuntu 20.04.6 LTS
  • Browser + version: Firefox 116.0 (64-Bit)
  • It can connect to i-doit to select / add CI from cmdb via API
  • It can not connect to i-doit to select / add CI from cmdb via API
Do you have any idea what’s went wrong there?
Thanks
Monica
See the documentation:
https://admin-docs.zammad.org/en/latest/system/integrations/i-doit.html
Ensure that your configuration fits to that.
