Problem
We’re sending “your ticket has been closed” mails to our customers. Naturally we use the condition State - closed
but this applies for every update inside a closed ticket since you can’t set a condition like Action - closed
(there’s only created
or changed
available atm).
That’s a problem because some agents tend to close their tickets before putting every needed information in it. That creates a lot of those mails thus spamming the customer.
Current workaround including more problems
What where doing currently as a workaround is adding another condition:
Closed time - 1 minute ago
That way when 1 minute has passed after closing the ticket no more mails will be sent.
It works but it’s kinda quick & dirty + it creates another problem:
Opening a already closed ticket doesn’t seem to null the closed time so no more mail will be sent when the ticket is closed again.
FR
Adding a Action - closed
condition would handle all those problems and it should be relatively easy to implement because you just need to check for one thing:
Did the state
change from ANY state
except closed
to closed
cheers
