- Used Zammad version: 3.1
- Used Zammad installation source: Debian Package
- Operating system: Debian
- Browser + version: Chrome
Adding of a reference to an i.-doit object via API; is that possible?!
Yes, if you know idoit-object-IDs it should be possible.
The idoit information lives inside the preferences array of Tickets.
In preferences, it would like this: "idoit"=>{"object_ids"=>[]}.
Also there’s the following API routes (undocumented) that you’d need to fiddle around on your own with:
api_v1_integration_idoit POST /api/v1/integration/idoit(.:format) integration/idoit#query
GET /api/v1/integration/idoit(.:format) integration/idoit#query
api_v1_integration_idoit_verify POST /api/v1/integration/idoit/verify(.:format) integration/idoit#verify
api_v1_integration_idoit_ticket_update POST /api/v1/integration/idoit_ticket_update(.:format) integration/idoit#update
