Thanks a lot for the checklists feature, it is really useful.
It would be really great if we can add checklists to tickets via triggers.
Certain reoccuring tickets always need the same checklist.
For example, new employee process which always has the same steps which need to be done.
I am not able to select a checklist in the trigger creation.
I want to be able to create a trigger which, if certain requirements are met, adds a checklist to a specific ticket.
As a workaround, you can perform a webhook against the zammad server.
Add a trigger with “Ticket - Action: created” and a group where this trigger belongs to. Then create a webhook with own payload:
use at your own risk
"ticket_id": "#{ticket.id}",
"template_id": 2
Endpoint is /api/v1/checklists
You have to know the template id of your checklist. You can fetch this by doing a get request against the checklists endpoint to get a list of all checklist templates.
+1 assigning checklists as a trigger action is actually very handy. If a ticket subject contains keywords, the matching checklist could be attached automatically.
Checklists exist per ticket, but completion is not enforced and they are not tied to states.
Processes with mandatory steps per phase (e.g. intake questions before review, a review confirmation before closing) rely purely on agent discipline; steps get skipped.
Checklists are free-form per ticket; Core Workflow cannot require checklist completion for a state change, and triggers cannot manipulate checklists.
Checklists that are bound to a ticket state and must be completed before the ticket can move on (per-state required checklists). In addition, triggers should be able to manipulate checklists (e.g. apply a checklist template or check off items) so the process logic can drive them automatically.
