Add certificate expiration warning in "Monitoring"
    I am able to add SSL-certificates in a lot of situations in Zammad now. They usually expire. While you can handle update reminders outside of Zammad, it would be nice, if Zammad warns if a used certificate is about to expire.
    I use a SSL certificate in Zammad to secure my SAML-authentication and my certificate expires, so my users are not able to login.
I use M365-authentication and the client secret expires, so my users are not able to login.
    There is no warning about upcoming expirations.
  2. What is your expectation/what do you want to achieve?
    Display a warning in “Monitoring” when a used certificate is about to expire.
About the second use case, I think we do not have any detailed information in the M365 Third-Party authentication context.
