Activity stream on smaller screens not visible
  • Used Zammad version: 6.4.1-1733753551.14e9d424.jammy
  • Operating system: Ubuntu
  • Browser + version: n/a
It seems this should be something simple but I just can’t figure it out.
On screens with a smaller resolution, in combination maybe with high display scaling, the activity stream is no longer visible in the dashboard view. That’s perfectly fine but I’d assume it should still be possible to get to it somehow because it’s not exactly gone. I can just zoom out and it’s there. But how do I access it directly without zooming out?
Thanks for your hints.
Correct. The UI does not display all parts of the UI if the width is not enough.
There’s no workaround.
