S1XP4K
1
- Used Zammad version: currently unknown
- Operating system: debian
- Browser + version: chrome
- login with AD credentials should be possible
One of our Domain Controllers was removed from Active Directory before I was able to change the settings in zammads webUI.
Now I can’t login to change it.
Is there an option to add a local admin-user from console in order to login and set the new connection?
Or is there an option to change the IP to the current server?
regards
Rico
Sal
2
There must be a local admin account already. You would need that to configure zammad during the initial setup.
If you can’t login to the UI, then you’ll need to use CLI.
https://docs.zammad.org/en/latest/admin/console/working-on-users.html
S1XP4K
3
thx 4 the link.
Didn’t found it by crawling the documentation …
btw: we found the install-documentation with the localadmin credentials and were able to login and change it via the gui.
Now it’s back online
thx 4 help @ all
greetz
Rico
system
Closed
4
