About knowledge base
Hi!
The way to make Zammad even better by upgrade knowledge base:
  1. Can you please add graphical panel to select text formatting in text fields? Like bold, italics, numbered/ordered list, tables, text alignment. It will be very handy and will be more comfortable for using it.
  2. There is no way to add tables in articles. If there will be fuctions to create tables inside Zammad it will make knowledge base in Zamad more popular would obviate the need to use some separate knowledge base
