Used Zammad version:
Zammad Version 2.6.x -
Used Zammad installation source: (source, package, …):
Zammad from https://dl.packager.io/srv/deb/zammad/zammad/stable/ubuntu 18.04 main -
Operating system:
Ubuntu 18.04 4.15.0-36-generic x86_64 GNU/Linux -
Webserver:
Server version: Apache/2.4.29 (Ubuntu)
Server built: 2018-10-03T14:41:08 -
Browser + version:
Firefox 62.0.3 (64-Bit)
No Errors
- When I’m entering our Zammad URL, everything is working fine, but I noticed the 503 Error.
With a Apache log telling me:
**[Thu Oct 11 16:32:54.104903 2018] [proxy:warn] [pid 4287:tid 139648034662144] [client 172.30.30.1:44201] AH01144: No protocol handler was valid for the URL /ws (scheme 'ws'). If you are using a DSO version of mod_proxy, make sure the proxy submodules are included in the configuration using LoadModule.**
But I’v got already the required Modules enabled:
apache2ctl -M
Loaded Modules:
core_module (static)
so_module (static)
watchdog_module (static)
http_module (static)
log_config_module (static)
logio_module (static)
version_module (static)
unixd_module (static)
access_compat_module (shared)
alias_module (shared)
auth_basic_module (shared)
authn_core_module (shared)
authn_file_module (shared)
authz_core_module (shared)
authz_host_module (shared)
authz_user_module (shared)
autoindex_module (shared)
deflate_module (shared)
dir_module (shared)
env_module (shared)
filter_module (shared)
headers_module (shared)
mime_module (shared)
mpm_event_module (shared)
negotiation_module (shared)
proxy_module (shared)
proxy_http_module (shared)
proxy_wstunnel_module (shared)
reqtimeout_module (shared)
rewrite_module (shared)
setenvif_module (shared)
socache_shmcb_module (shared)
ssl_module (shared)
status_module (shared)
My Apache Config is:
<VirtualHost *:80>
ServerName our.domain.com
## don't loose time with IP address lookups
HostnameLookups Off
## needed for named virtual hosts
UseCanonicalName Off
## configures the footer on server-generated documents
ServerSignature Off
ProxyRequests Off
ProxyPreserveHost On
<Proxy localhost:3000>
Require local
</Proxy>
ProxyPass /assets !
ProxyPass /favicon.ico !
ProxyPass /robots.txt !
ProxyPass /ws ws://localhost:6042/
ProxyPass / http://localhost:3000/
DocumentRoot "/opt/zammad/public"
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory "/opt/zammad/public">
Require all granted
</Directory>
</VirtualHost>
netstat -tulpn
tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 639/systemd-resolve
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 706/sshd
tcp 0 0 127.0.0.1:3000 0.0.0.0:* LISTEN 678/puma 3.11.0 (tc
tcp 0 0 127.0.0.1:5432 0.0.0.0:* LISTEN 859/postgres
tcp 0 0 127.0.0.1:6042 0.0.0.0:* LISTEN 648/script/websocke
tcp6 0 0 127.0.0.1:9300 :::* LISTEN 739/java
tcp6 0 0 ::1:9300 :::* LISTEN 739/java
tcp6 0 0 :::22 :::* LISTEN 706/sshd
tcp6 0 0 :::443 :::* LISTEN 4278/apache2
tcp6 0 0 :::80 :::* LISTEN 4278/apache2
tcp6 0 0 127.0.0.1:9200 :::* LISTEN 739/java
tcp6 0 0 ::1:9200 :::* LISTEN 739/java
udp 21504 0 127.0.0.53:53 0.0.0.0:* 639/systemd-resolve
- Firewalls are completly disabled
- No Proxy , transparent proxy or any kind of proxy
Does someone has an idea what is missing here ?
