Hello everyone,
I am getting 502 bad gateway.
The problem is for me to start zammad-scheduler service.
It fails with following errors
[root@zmd4 zammad]# systemctl start zammad-scheduler
Job for zammad-scheduler.service failed because the control process exited with error code. See “systemctl status zammad-scheduler.service” and “journalctl -xe” for details.
[root@zmd4 zammad]# systemctl status zammad-scheduler.service
● zammad-scheduler.service - Zammad scheduler
Loaded: loaded (/etc/systemd/system/zammad-scheduler.service; disabled; vendor preset: disabled)
Active: activating (start) since Thu 2021-08-05 19:12:30 UTC; 2s ago
Main PID: 30446 (code=exited, status=0/SUCCESS); : 15993 (ruby)
CGroup: /system.slice/zammad-scheduler.service
└─15993 script/scheduler.rb start
Aug 05 19:12:30 zmd4.voipe.cc systemd[1]: zammad-scheduler.service holdoff time over, scheduling restart.
Aug 05 19:12:30 zmd4.voipe.cc systemd[1]: Stopped Zammad scheduler.
Aug 05 19:12:30 zmd4.voipe.cc systemd[1]: Starting Zammad scheduler…
[root@zmd4 zammad]# journalctl -xe
Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /usr/local/rvm/gems/ruby-2.6.6/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/loaded_features_index.rb:65:in register' Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /usr/local/rvm/gems/ruby-2.6.6/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:20:in
require_with_bootsnap_lfi’
Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /usr/local/rvm/gems/ruby-2.6.6/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:29:in require' Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /usr/local/rvm/gems/ruby-2.6.6/gems/activesupport-5.2.4.6/lib/active_support/dependencies.rb:291:in
block in require’
Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /usr/local/rvm/gems/ruby-2.6.6/gems/activesupport-5.2.4.6/lib/active_support/dependencies.rb:257:in load_dependency' Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /usr/local/rvm/gems/ruby-2.6.6/gems/activesupport-5.2.4.6/lib/active_support/dependencies.rb:291:in
require’
Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /usr/local/rvm/gems/ruby-2.6.6/gems/railties-5.2.4.6/lib/rails/all.rb:3:in <main>' Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /usr/local/rvm/gems/ruby-2.6.6/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in
require’
Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /usr/local/rvm/gems/ruby-2.6.6/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in block in require_with_bootsnap_lfi' Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /usr/local/rvm/gems/ruby-2.6.6/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/loaded_features_index.rb:65:in
register’
Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /usr/local/rvm/gems/ruby-2.6.6/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:20:in require_with_bootsnap_lfi' Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /usr/local/rvm/gems/ruby-2.6.6/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:29:in
require’
Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /usr/local/rvm/gems/ruby-2.6.6/gems/activesupport-5.2.4.6/lib/active_support/dependencies.rb:291:in block in require' Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /usr/local/rvm/gems/ruby-2.6.6/gems/activesupport-5.2.4.6/lib/active_support/dependencies.rb:257:in
load_dependency’
Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /usr/local/rvm/gems/ruby-2.6.6/gems/activesupport-5.2.4.6/lib/active_support/dependencies.rb:291:in require' Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /opt/zammad/config/application.rb:5:in
<top (required)>’
Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /opt/zammad/config/environment.rb:4:in require_relative' Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: /opt/zammad/config/environment.rb:4:in
<top (required)>’
Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: script/websocket-server.rb:15:in require' Aug 05 19:13:03 zmd4.voipe.cc bash[19598]: script/websocket-server.rb:15:in
<top (required)>’
Aug 05 19:13:03 zmd4.voipe.cc systemd[1]: zammad-websocket.service failed.
Aug 05 19:13:03 zmd4.voipe.cc systemd[1]: zammad-rails.service failed.
Aug 05 19:13:03 zmd4.voipe.cc systemd[1]: zammad-websocket-1.service failed.
Aug 05 19:13:04 zmd4.voipe.cc systemd[1]: zammad-websocket-1.service failed.
Aug 05 19:13:04 zmd4.voipe.cc systemd[1]: Failed to start Zammad scheduler.
– Subject: Unit zammad-scheduler.service has failed
– Defined-By: systemd
– Support: systemd-devel Info Page
– Unit zammad-scheduler.service has failed.
– The result is failed.
Aug 05 19:13:04 zmd4.voipe.cc systemd[1]: zammad-scheduler.service failed.
Aug 05 19:13:05 zmd4.voipe.cc systemd[1]: zammad-websocket-1.service failed.
Aug 05 19:13:05 zmd4.voipe.cc systemd[1]: start request repeated too quickly for zammad-websocket-1.service
Aug 05 19:13:05 zmd4.voipe.cc systemd[1]: Failed to start zammad-websocket-1.service.
– Subject: Unit zammad-websocket-1.service has failed
– Unit zammad-websocket-1.service has failed.
Aug 05 19:13:06 zmd4.voipe.cc bash[20023]: bundler: failed to load command: script/rails (script/rails)
Aug 05 19:13:06 zmd4.voipe.cc bash[20023]: Errno::EACCES: Permission denied - bs_fetch:atomic_write_cache_file:open
Aug 05 19:13:06 zmd4.voipe.cc bash[20023]: /usr/local/rvm/gems/ruby-2.6.6/gems/bootsnap-1.3.2/lib/bootsnap/compile_cache/iseq.rb:37:in fetch' Aug 05 19:13:06 zmd4.voipe.cc bash[20023]: /usr/local/rvm/gems/ruby-2.6.6/gems/bootsnap-1.3.2/lib/bootsnap/compile_cache/iseq.rb:37:in
load_iseq’
Aug 05 19:13:06 zmd4.voipe.cc bash[20023]: /usr/local/rvm/gems/ruby-2.6.6/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in require' Aug 05 19:13:06 zmd4.voipe.cc bash[20023]: /usr/local/rvm/gems/ruby-2.6.6/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in
block in require_with_bootsnap_lfi’
Aug 05 19:13:06 zmd4.voipe.cc bash[20023]: /usr/local/rvm/gems/ruby-2.6.6/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/loaded_features_index.rb:65:in register' Aug 05 19:13:06 zmd4.voipe.cc bash[20023]: /usr/local/rvm/gems/ruby-2.6.6/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:20:in
Aug 05 19:13:06 zmd4.voipe.cc bash[20023]: /usr/local/rvm/gems/ruby-2.6.6/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:29:in require' Aug 05 19:13:06 zmd4.voipe.cc bash[20023]: /usr/local/rvm/gems/ruby-2.6.6/gems/activesupport-5.2.4.6/lib/active_support/dependencies.rb:291:in
block in require’
Aug 05 19:13:06 zmd4.voipe.cc bash[20023]: /usr/local/rvm/gems/ruby-2.6.6/gems/activesupport-5.2.4.6/lib/active_support/dependencies.rb:257:in load_dependency' Aug 05 19:13:06 zmd4.voipe.cc bash[20023]: /usr/local/rvm/gems/ruby-2.6.6/gems/activesupport-5.2.4.6/lib/active_support/dependencies.rb:291:in
require’
Aug 05 19:13:06 zmd4.voipe.cc bash[20023]: script/rails:8:in `<top (required)>’
Aug 05 19:13:06 zmd4.voipe.cc systemd[1]: zammad-rails.service failed.
Aug 05 19:13:07 zmd4.voipe.cc systemd[1]: zammad-websocket.service failed.
Aug 05 19:13:07 zmd4.voipe.cc systemd[1]: start request repeated too quickly for zammad-websocket-1.service
Aug 05 19:13:07 zmd4.voipe.cc systemd[1]: Failed to start zammad-websocket-1.service.
Aug 05 19:13:07 zmd4.voipe.cc systemd[1]: zammad-websocket-1.service failed.
I am not sure what happened.
Please kindly teach me.
Thanks in advance,
Maksym
