im getting 502 Error after upgrading to Version 6.0
i Addet the Cable
location /cable {
proxy_http_version 1.1;
proxy_read_timeout 86400;
But it doesn’t change a thing.
My Ngnix config.
upstream zammad-railsserver {
server 127.0.0.1:3000;
upstream zammad-websocket {
server 127.0.0.1:6042;
server {
listen 80;
listen [::]:80;
server_name zammad.domain.de, support.domain.de;
server_tokens off;
location /.well-known/ {
root /var/www/html;
return 301 https://$server_name$request_uri;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
server_name zammad.domain.de, support.Domain.de;
server_tokens off;
ssl_certificate /etc/ssl/certificate.crt;
ssl_certificate_key /etc/ssl/key.pem;
ssl_protocols TLSv1.2;
ssl_ciphers 'sdsad';
ssl_dhparam /etc/ssl/dhparam.pem;
ssl_prefer_server_ciphers on;
ssl_session_timeout 180m;
ssl_stapling on;
ssl_stapling_verify on;
ssl_trusted_certificate /etc/ssl/root.crt;
resolver 8.8.8.8 8.8.4.4;
add_header Strict-Transport-Security "max-age=31536000" always;
location = /robots.txt {
access_log off; log_not_found off;
location = /favicon.ico {
root /opt/zammad/public;
client_max_body_size 50M;
expires max;
location /ws {
# action cable
location /cable {
location / {
proxy_read_timeout 180;
gzip on;
gzip_proxied any;
Thanks
