- Used Zammad version: 6.1.0
- Operating system: Ubuntu in a LXC container on Proxmox
- Browser + version: On laptop, Firefox 119.0.1
- Following the guide in Aruba’s hosting (that can be found here) I should be able to set the email channel for customers.
- I’ve tried both the SSL and non SSL. for both configurations (SSL and non SSL). the inbound settings goes fine, but the outbound returns
501 HELO requires valid address when setting mail outboundwhen I set the user field ashelpdesk@mydomain.com. By following aruba’s guidelines, with the same parameter fed to zammad I was able to setup both thunderbird and nextcloud’s outbound mail for the server. - I’ve also tried the same mail of nextcloud (in order to see if it was a problem of the specific
helpdeskmailbox, even if I was able to set it up correctly in thunderbird). - I’ve also tried to put simply
helpdeskinstead ofhelpdesk@mydomain.it, but returns the same error (also because even from aruba’s website I usehelpdesk@mydomain.itto log in to my mailbox).
- Setup Zammad with docker compose
- Subscribe to Aruba and get a webmail
- Try to set up that mail as email channel
