Hello!
Thank you for pointing me to the logs, here is what I see when I try to click the knowledge base button when I am logged in as an admin or an agent with KB access, it seems to be expecting a port component and is erroring out with or without a preview_token present in the request url.
Any help here would be greatly appreciated. I cannot ship a system where logged in users cant see the KB that they are supposed to create and maintain.
URL: /help/en-us?preview_token=ViAka-bSzBcIx8kcED5RPQ9VosymB6Iz1-e1Hfn2bQ5A94FF50G4-XonvareaGgE
Log:
I, [2024-01-24T19:18:30.076186#452-143260] INFO -- : Started GET "/help/en-us?preview_token=ViAka-bSzBcIx8kcED5RPQ9VosymB6Iz1-e1Hfn2bQ5A94FF50G4-XonvareaGgE" for 97.126.115.237 at 2024-01-24 19:18:30 +0000
I, [2024-01-24T19:18:30.080511#452-143260] INFO -- : Processing by KnowledgeBase::Public::CategoriesController#index as HTML
I, [2024-01-24T19:18:30.080607#452-143260] INFO -- : Parameters: {"preview_token"=>"ViAka-bSzBcIx8kcED5RPQ9VosymB6Iz1-e1Hfn2bQ5A94FF50G4-XonvareaGgE", "locale"=>"en-us"}
I, [2024-01-24T19:18:30.126771#452-143260] INFO -- : Rendered knowledge_base/public/categories/index.html.erb within layouts/knowledge_base (Duration: 13.9ms | Allocations: 6325)
I, [2024-01-24T19:18:30.129663#452-143260] INFO -- : Rendered layout layouts/knowledge_base.html.erb (Duration: 16.8ms | Allocations: 7453)
E, [2024-01-24T19:18:30.129843#452-143260] ERROR -- : bad component(expected port component): "//helpdesk.leftovers.today" (ActionView::Template::Error)
app/helpers/knowledge_base_helper.rb:59:in `build_zammad_link'
app/helpers/knowledge_base_helper.rb:51:in `build_kb_link'
app/views/knowledge_base/public/_top_banner.html.erb:14
app/helpers/knowledge_base_top_bar_helper.rb:45:in `render_top_bar_if_needed'
app/views/layouts/knowledge_base.html.erb:20
app/controllers/application_controller/has_download.rb:17:in `block (4 levels) in <module:HasDownload>'
app/controllers/application_controller/has_download.rb:16:in `block (3 levels) in <module:HasDownload>'
app/controllers/application_controller/has_download.rb:15:in `block (2 levels) in <module:HasDownload>'
I, [2024-01-24T19:18:30.133043#452-143260] INFO -- : Rendered inline template (Duration: 0.3ms | Allocations: 242)
I, [2024-01-24T19:18:30.133174#452-143260] INFO -- : Completed 500 Internal Server Error in 53ms (Views: 0.6ms | ActiveRecord: 12.5ms | Allocations: 25731)
URL: /help/en-us
Log:
I, [2024-01-24T19:27:50.293357#452-141940] INFO -- : Started GET "/help/en-us" for 97.126.115.237 at 2024-01-24 19:27:50 +0000
I, [2024-01-24T19:27:50.297778#452-141940] INFO -- : Processing by KnowledgeBase::Public::CategoriesController#index as HTML
I, [2024-01-24T19:27:50.297909#452-141940] INFO -- : Parameters: {"locale"=>"en-us"}
I, [2024-01-24T19:27:50.341416#452-141940] INFO -- : Rendered knowledge_base/public/categories/index.html.erb within layouts/knowledge_base (Duration: 12.3ms | Allocations: 6330)
I, [2024-01-24T19:27:50.343951#452-141940] INFO -- : Rendered layout layouts/knowledge_base.html.erb (Duration: 14.8ms | Allocations: 7484)
E, [2024-01-24T19:27:50.344127#452-141940] ERROR -- : bad component(expected port component): "//helpdesk.leftovers.today" (ActionView::Template::Error)
I, [2024-01-24T19:27:50.346824#452-141940] INFO -- : Rendered inline template (Duration: 0.3ms | Allocations: 247)
I, [2024-01-24T19:27:50.346950#452-141940] INFO -- : Completed 500 Internal Server Error in 49ms (Views: 0.6ms | ActiveRecord: 11.6ms | Allocations: 25818)
But when I am not logged in, it does not expect a port component and renders the knowledge base correctly:
URL: /help/en-us
I, [2024-01-24T19:26:43.478818#452-143260] INFO -- : Started GET "/help/en-us" for 104.28.116.106 at 2024-01-24 19:26:43 +0000
I, [2024-01-24T19:26:43.483249#452-143260] INFO -- : Processing by KnowledgeBase::Public::CategoriesController#index as HTML
I, [2024-01-24T19:26:43.483295#452-143260] INFO -- : Parameters: {"locale"=>"en-us"}
I, [2024-01-24T19:26:43.507179#452-143260] INFO -- : Rendered knowledge_base/public/categories/index.html.erb within layouts/knowledge_base (Duration: 2.0ms | Allocations: 763)
I, [2024-01-24T19:26:43.520694#452-143260] INFO -- : Rendered layout layouts/knowledge_base.html.erb (Duration: 15.5ms | Allocations: 7444)
I, [2024-01-24T19:26:43.521844#452-143260] INFO -- : Completed 200 OK in 38ms (Views: 12.0ms | ActiveRecord: 10.6ms | Allocations: 14524)
