Dear All,
We already setup Zammad in a separate domain “www.example.com”, and we want to integrate it with other services, so we are moving to “www.example.com/zammad” by enabling NGINX layer 7 HTTP load-balancing. NGINX is the frontend to route to specific services based HTTP URI request, and zammad is one of it. If you know the changes needed in the source code or configuration, then pls let me know. I really appreciate your support and take the time to read it.
Thanks for your support
Dinesh
