Yes, but it doesn’t…
Die folgenden Pakete haben unerfüllte Abhängigkeiten:
zammad : Hängt ab von: redis ist aber nicht installierbar
An “apt-cache show zammad” shows "Depends on “redis” not “redis-server”. Can that be a problem?
Package: zammad
Filename: pool/main/zammad_6.0.0-1686825303.79954d1a.xenial_amd64.deb
MD5sum: bcbaeaf6c8b0a7a4f3a54bdb118a0dfa
SHA1: 4977309702aa883bcd55e607445a7573d5bb24e1
SHA256: 5095c1ffd837ea195f3ce88c495b8cb348edebe98d47ad8cc3a7614c7a466042
Version: 6.0.0-1686825303.79954d1a.xenial
License: unknown
Vendor: Packager.io <https://packager.io>
Architecture: amd64
Maintainer: support@packager.io
Installed-Size: 468121
Depends: libpq5, libsqlite3-0, openssl, libxml2, libxslt1.1, libreadline6, libssl1.0.0, libevent-2.0-5, libevent-core-2.0-5, libevent-extra-2.0-5, curl, elasticsearch|elasticsearch-oss, nginx|apache2, postgresql|mysql-server|mariadb-server, libimlib2, shared-mime-info, redis
Provides: zammad
Section: default
Priority: optional
Homepage: https://zammad.org
Description: Zammad is a web based open source helpdesk/customer support system
Description-md5: a57c5e55d3ec7da3ef8af7f15126049d
I’ll go to an unscheduled verification process for all supported packages and distrubutions.
This will take roughly until Monday. Please bear with me.
That’s the issue in older dpkg-based systems (Ubuntu, Debian) the package is called redis-server. With the new stable release of Debian 12, the maintainer introduced a meta package redis. We will check the correct package name for the supported OS and fix the dependencies. Sorry for the inconvenience.
Thanks a lot, that should help. I’m sorry for bothering you with the old Ubuntu 16.04 which is dying anyway… But I need a straight and relyable way to go to the Zammad 6 on a new server and beside the migration from mysql to postgres with a very big database…
By the way, thanks for the wonderful Zammad! ![]()
Thank you @AchMol for digging that out, so the core team is able to correct the error.
Tahnk you @tschaefer @MrGeneration for correcting the error timely.
Did updating Zammad to 6.0 work for you now? I still see the dependency of ‘redis’.
We have a control issue for that and it’s not yet solved. Please be patient.
JFI the issue should be resolved now. Stable packages have built and are available by now.
Thank you very much. Upgrading did work now.
