Is it possible to running zammad without elasticsearch?
I have been running zammad with elasticsearch, but i have a problem with Elasticsearch instance, it need big resources..
The other problem is we need to reindex Elasticsearch after:
add new field on object
Delay when search after adding new user or group. rake zammad:searchindex:rebuild
it takes an hour, depends the documents count.
so i think if we are disabling it, how is it going?
