Zammad db delta backups
the backup of zammad DB and filesystem with the existing backup script is fine to make a complete dump.
However this script takes a long runtime and produces large backup files.
So we will execute this full backup every weekend.
However in case of desaster we will loose important data.
The requirement is to make (delta) backups of pgsql database every hour.
has anybody has some hints how to setup this?
BR
Thomas
Backing up the database incrementally is usually not exactly possible without having a full dump first. The provided script is a suggestion not a hard to use must. You can use it to extend it or improve it in a scope you need.
