I was searching for the zammad homepage via google, but i didn’t found it.
It seems, it was dropped from google index?
There are many Knowledge Base sites visible in the results.
It highly depends on your search terms I guess.
Duckduckgo definitely delivers “the better results”.
Yeah i know. But when you search directly for zammad.com the main page should come first, but it doesn’t. So there is something wrong with the index:
Searched via google chrome on google in incognito mode:
You are right, zammad.com is completely gone.
Only subdomains are there.
Thank you for the heads up. We could spot a faulty vhost file to be responsible for that …
We’ve taken counter measurements. Hopefully entries are back asap.
