Updated 2.9.0 -> 3.0.0 (source, ubuntu-18.04): No issues
I just finished updating my zammad instance, no issue at all. I’m using the source installation on ubuntu-18.04.
Near the end, I’ve seen these warnings:
Bundle complete! 99 Gemfile dependencies, 141 gems now installed.
Gems in the groups test, development and postgres were not installed.
Use `bundle info [gemname]` to see where a bundled gem is installed.
Post-install message from i18n:
HEADS UP! i18n 1.1 changed fallbacks to exclude default locale.
But that may break your application.
Please check your Rails app for 'config.i18n.fallbacks = true'.
If you're using I18n (>= 1.1.0) and Rails (< 5.2.2), this should be
'config.i18n.fallbacks = [I18n.default_locale]'.
If not, fallbacks will be broken in your app by I18n 1.1.x.
For more info see:
https://github.com/svenfuchs/i18n/releases/tag/v1.1.0
Post-install message from icalendar:
ActiveSupport is required for TimeWithZone support, but not required for general use.
I ignored them and everything seems to work well. Do you propose any action?
Thanks for your work and support, Uli
Maybe @anon29869905 can tell :slight_smile:
Hey Uli! These are only warnings /notices to us (the developers) that some things in our dependencies have changed. We already covered that so you can just ignore it. Have a good time using Zammad 3.0!
Thanks a lot for your feedback. So far, my team is very pleased with the new version. They didn’t even notice the update :wink: I’ll ask them to play with the knowledgebase next week and post my findings here. Schöne Pfingsten und vielen Dank nochmal für die tolle neue Version! LG,Uli
This topic was automatically closed 41 days after the last reply. New replies are no longer allowed.
