In trying to figure out the most effective way to use our tickets tagged as spam to train our spam filters, I came up with a solution that seems to work pretty well. The does require you to use the console, so fair warning for those of you who are faint of heart.
I have posted a snippet on Github that you can use to look for tickets with a “spam” tag and then export the raw emails as files that you can then feed into sa-learn to train your Spamassassin filters.
This is great - glad to have seen you actually implemented the idea. Spam in the helpdesk is a real pain point.
I’m curious if you have found an optimal way to deal with the detected spam in Zammad (not what your agents manually mark as spam, rather what you server has already detected as spam)
We are allowing emails with X-Spam-Flag: YES to come to Zammad, but then have a Zammad email filter that adds the ‘spam’ tag and closes those tickets automatically.
Perhaps we should use different tags for agent marked spam vs SpamAssassin marked spam that is auto-closed on arrival to avoid a feedback loop.
Anyways, we still have a fair amount of garbage tickets in our system but at least they are closed and if need be we could still find them.
That is exactly what we settled on; it allows us to steer the training of tickets into only those that are manually tagged.
Same here basically, if either tag is detected (manual or auto), once in the ticket system, it is shown in a spam view that allows agents to access it in the event of improperly tagged spam. Additionally, we have a macro for Tag as Spam and Tag as Not Spam, which will add or remove ham and spam tags for the users and make sure that the email system is retrained appropriately going forward. Just remember that triggers are executed in alphabetical order in the listing!
The only issue I did not think of, that we recently had to address, was agents not using the macro to tag tickets and instead manually tagged it via the UI as spam and then someone else manually tagging it as ham, which ends up with the ticket having both. Not much you can really do here other than retraining of the user.
