I can’t find a way to search for an exact match via API call when looking for a user with a certain email address.
Let’s assume I have three users in the database:
User #1 email address: userone+test1@test.com
User #2 email address: usertwo+test1@test.com
User #3 email address: test1@test.com
Now I want to change the email address of user #3 in the database.
Therefore I try to get the corresponding ID of user #3 via REST API call:
/api/v1/users/search?query=email:test1@test.com
The API request returns user #1, user #2 and user #3 in the JSON response.
So what I have to do now in my code is to check for the exact match of the email address “test1@test.com” in all users returned in the JSON response object.
It would be more convenient if the API request would only return the user with an exact match in its email address.
Does anybody know if there is a way to achieve this via an API call?
Hi Hubertus,
try /api/v1/users/search?query=login:test1@test.com
so “login” instead of “email”. That should only return 1 unique value.
Cheers,
Gijs
Hi escomsilio,
this did not do the trick. I tried your suggestion but both calls
and
can both return more than one result. They do not look for an exact macht an seem to use the elastic search.
Thank you for your reply!
Hmm, sorry, than I have no idea. Maybe @MrGeneration has a solution?
Edit: Whoopsie, I should have tested the other way around too.
Checking with devs.
invalid statement
It’s the way you querry.
You’re actually running a not explicit search query (the UI does the same actually).
So do overcome your issue, you’ll need email: "<value>"
. Should work for login too.
See the differences:
# /api/v1/search?query=email:"sample@example.com"
"result": [
"id": 17,
"type": "User"
and your approach
# /api/v1/search?query=email:sample@example.com
"result": [
"id": 19,
"type": "User"
"id": 18,
"type": "User"
"id": 17,
"type": "User"
Now that was a ride.
Developers provided the following background info:
Es is saving only “index” data in the attribute value. E. g. for attachments, not the attachment is saved, only the indexed words.
In this case es can may split the value of “email” into two words to save. one
and sample@example.com
. It’s up to the analyzer which is used for this attribute.
In case you want to search for the not indexed/analyzed values, you need to search for attribute.keyword
. Note: This will not use any search indexes.
So in our case the correct API call would be:
/api/v1/search?query=email.keyword:"sample@example.com"
I did verify this behavior and it works on my machine™.
Does that also apply for
/api/v1/users/search?limit=1&query=email.keyword:"sample@example.com"
I verified that it is working using postman but couldn’t find documentation on it.
Would it make sense to add the “exact match” use case here in the API docu?
We are using this call for the “Create user if it does not exist, otherwise return existing user” use case. So we really need to be sure it is an exact match.
you can use the guess: method.
Body{
customer_id = “guess:$mail”
that does exactly the same.
ohhhh really???
I had soooo many Problems and now i see i just have to put the value in ’ '.
OMG im so exited weather my requests in powershell are working now.
search?query=state.name:‘open’%20AND%20group.name:‘groupname’&limit=10&expand=true"
nooo its not working again.
Personally I’d feel this making more sense within the search documentation of the user docs. Preferably the advanced search: zammad-user-documentation/advanced/search.rst at main · zammad/zammad-user-documentation · GitHub
The reason for that is that finding things in Zammad does affect “normal users” as well and may be a use case. Also I hate duplicate information to be honest. I’ll rework the api documentation in the future™ and will reference the search references of the user docs. I believe that should help better than sending a non technical user into the api reference
Use the .keyword
slug, it’s your friend!
group.name.keyword
thank you so much for your fast answer. I am really frustradet, cause im working at this automation such a long time and it definitly seems randomly if it works or not. At first everything works
We Detect our Server Errors and the Ticket will be created automaticly in Zammad.
But When i want to control if there is already a ticket open, i have to use this Request. And i dont even know whats wrong. Would be awesome if you can check the following.
$gettickets = 'https://mydomain.de/api/v1/tickets/search?query=group.name.keyword:"smartmanaged"%20AND%20state.name.keyword:"open"&expand=true'
$tJson = (Invoke-WebRequest -Uri $gettickets -Headers $headers -Method GET).Content
$tJson
$tobjects = ConvertFrom-Json -InputObject $tJson
$tobjects
and it gives me this
group : smartmanaged
ticket_time_accounting : {}
state : closed
priority : 2 normal
I dont even know even with your keyword slug
Please ensure that your searchindex is allright.
It sounds like you have outdated data in your elasticsearch index.
You may want to ensure the exact search does work via the UI - if it does it also has to via API.
I second the idea of improving the API documentation on search topics. While writing a PHP script to update the Users (hosted Zammad) from our Active Directory, it took me a while to figure out that the default search is not exact, i.e. query=login:abc will also return logins abcd, abce, …
Some hint about this in the API documentation would have been nice.
FWIW, I came around with the solution of reading the whole user base into an array with login and id, doing exact search in my array, and then only using the id to identify the user for API calls.
Also, it would be nice to have the API documentation completed on combined searches like AND, OR etc.
Pull requests are very welcome.
Sorry but no.
We have advanced search techniques documented already:
https://user-docs.zammad.org/en/latest/advanced/search.html
Putting this at 2 or 3 places might help you do search less, however, does raise the maintenance required for the documentation by factor 3. I’m already struggling keeping up and would need like 3 times the time I invest into Zammad right now.
Uuups, I did not even expect this to be in the user documentation (and, to be fair, the API search doc does not point there, either). Thanks for the heads up!
And yes, I absolutely agree on your point of having this only at one place.
