Hi @mgruner and everyone,
I’m Igor (@igoraraujocosta on this Weblate instance, GitHub and Crowdin).
I run Zammad in production for my field service team and maintain the
pt-BR translation of InvenTree at 100% on Crowdin.
I recently completed and standardized the Brazilian Portuguese translation
across the whole Zammad project: stable, development, and both Hosted
Extensions components are now at 100% (up from ~83% on stable). I also
standardized terminology that was inconsistent in the existing corpus
(e.g. “ticket” appeared as ticket/tíquete/chamado) and fixed a few real
defects along the way — including 10 corrupted placeholders and one string
with an inverted meaning (“Not Assigned” was translated as “Assigned”).
Two things I couldn’t finish without help:
45 approved strings in stable (+3 in development) still carry the
old terminology. Weblate correctly protects approved strings from
uploads, so these are stuck inconsistent with the rest. I have the
full list (current vs. proposed) ready to share.
Glossary: I submitted 8 corrections as suggestions (my account
can only suggest, not edit glossary terms directly) — still pending
review.
I submitted a request through the contact form a while back but haven’t
heard back yet, so I wanted to also try here. Could someone either apply
the pending changes, or point me to how I could get reviewer rights for
pt-BR? I’d like to keep maintaining the language — next up is reviewing
the ~4,600 unreviewed strings and then the documentation project.
Happy to share files or answer any questions here or by email.
Thanks for maintaining such a great project and translation infrastructure!
Next time, please do not force notifications on others by mentioning them directly, please.
Sorry about that. I’ll keep that in mind for next time.
Thanks for the advice!
@igoraraujocosta thank you so much for reaching out, and for your contributions so far. I just granted you reviewer permission, which allows you to edit the glossary, and also mark strings as reviewed, freezing them for regular translators.
Again, thanks a lot for your help. Please feel free to reach out anytime if we can help you with something.
Hi Martin,
Thank you so much for granting me reviewer permission — it’s already made
a real difference. I’ve been using it to properly review and standardize
the whole pt-BR content, not just approve what was already there.
Status update:
- Hosted Extensions (stable + development): 100% translated and approved.
- Zammad stable: 100% translated, and I’m working through a full review
of the ~4,600 previously-unreviewed strings — currently past 1,500
approved and climbing steadily. This isn’t just rubber-stamping: I’ve
found and fixed a significant number of real errors along the way —
mistranslations, leftover English fragments, broken grammar, and quite
a few internal inconsistencies (the same term translated 3 different
ways in different places). Portuguese turned out to have accumulated
a lot of drift over time from multiple contributors without a shared
standard, so this cleanup was overdue.
- Zammad development: same approach starting now that it’s unlocked again.
- Glossary: fully corrected and standardized.
- User documentation (latest + pre-release): 100% translated and approved.
- Admin documentation: intentionally saved for last, since it’s by far
the largest piece (~5,400 strings) — I’ll get to it once stable/dev
are fully reviewed.
I noticed there’s an “Addons (Internal)” project on Weblate with German at 85% but no Portuguese (Brazil) language enabled yet. Could you add pt-BR there so I can start translating it too?
Thanks again for your trust and support — happy to keep going as long
as it’s useful.
Thanks a lot for the update @igoraraujocosta. Awesome! We’ll check the translated docs and take them online.
Addons (Internal) is not for public and should not be visible any more.
Thanks Martin.
I’m close to finishing the admin-doc translation work. I’ve noticed a recurring issue: whenever I try to download a translation file from Weblate, the corresponding component locks up right after (“Could not merge the repository” / merge conflict). This happened with zammad pre-release, more recently with admin documentation, and just now with “New Documentation at next.zammad.org” as well. It seems tied to an automatic repo sync hitting a conflict, not something I’m doing on my end, but wanted to flag the pattern in case it needs a manual git rebase/push fix on the backend.
Once the merge issue is resolved, I’ll be starting work on “New Documentation”. I will keep you posted on progress there too.
Hi @mgruner
Quick update — the recurring lock issue happened again, this time right after downloading the New Documentation (zammad-org) .po file for review. Same pattern as before: download → “Could not merge the repository” conflict shortly after. Wanted to keep you posted since it’s now happened three times across different components (zammad pre-release, admin documentation, and now new documentation).
100% done!
ll keep this under continuous review: whenever the docs get updated or new content is added, I’ll go through the corresponding translation to keep it error-free and in sync with the English source.
Let me know if anything comes up.
Thanks again!
Thanks for the hint about the error. We don’t have a clue yet, and will first try updating Weblate.
And thank you so much for your contributions!
