Hello Team Zammad,
do you have an approximate date when packages for Debian 12 Bookworm will be available on Packager.io (Packages for zammad/zammad)?
Thanks and all the best
Christian
Hello Team Zammad,
Christian
Hi @seraphyn,
can you please open an issue for this at Issues · zammad/zammad · GitHub? Thanks a lot ![]()
Ähem, there is only Report a bug, or security as an option…
@fliebe92 Should I really send an Issue under Report a bug ?
Just do it, I will take care of the form if needed. ![]()
Thanks! I already add correct labels etc. ![]()
package support highly depends on packager.io as our packager.
This is not a Zammad issue but an upstream issue.
I’m not aware of Debian 12 support added yet.
@seraphyn You already noticed it I guess, we have now packages ready for Debian 12. ![]()
@fliebe92 I do, indeed ![]()
That was definitely quickly
I will start here the first tests next week
Have a wonderful weekend
Same to you, I’m glad that we could help you out so quickly ![]()
