Monitoring and Health Check
  • Used Zammad version: 6.2
  • Operating system: Ubuntu 22
  • Browser + version: not relevant
  • Manually go and check the monitoring page
Dear all,
Can anyone recommend a solution for automatically monitoring the health check in the monitoring tab? For example, can a message be sent automatically in or by Zammad when the status changes? Or are there reliable and simple external tools?
How do you monitor your system?
Best regards
Not really Zammad related, but I use Uptime Kuma to check internal and external services.
I just check if the HTTPS login page responds. You can also do some random API calls and check if Zammad responds as expected.
Quite handy, as almost all my Uptime Kuma sensors create a Zammad ticket when they’re down. Only the Zammad sensor sends a mail if that ones down.
