Macros Dont work after upgrade 4.1 to 5.in overviews "Resolved"
Exactly that’s the issue. Ticket object called type causing this trouble.
type is a default object from early Zammad days. While it by now is a reserved value (if I remember correctly) it still has to be functional. We’ll see how above linked issue evolves.
Bang on i disabled this Object and now macros work thank you Sir God of Zammad Mr Generation
Can confirm it.
I have now implemented the “Label” in a completely new object “ticket_label”. And the object “type” disabled.
No more errors with the macros and bulk actions. :slight_smile:
I have also cleaned up the labels. Your “standard” what you noted, was stored as a key in the object “type”. For whatever reason. I have replaced that. As a precaution :wink:
I can only thank you again for your efforts! :slight_smile:
