Knowledge base first
So. I work as a nurse for a minicipality. I think Zammad would be a great match for us handeling questions around helthcare and systems but…
Is there a guide showing how to setu Knowledge Base as the first page for the website? I’ve gotten the domain https://uppsala.support. I’ve set Zammad up on a vpn with 12 gigs of ram. And it seems like it’s working good.
I have a second question: Since I only want to use zammad and no other front - Is there a way to add the chat and the form to the knowlage base?
Yes
https://user-docs.zammad.org/en/latest/extras/knowledge-base.html
There is no official way to do this.
You can add the code yourself, but the updates will overwrite the manual change.
Knowledge Base — Zammad User Documentation documentation
I have the Knowledb Base on as you se the url is: https://uppsala.support/help but that overkill to have it there. Id like it like so:
https://uppsala.support/ → Knowledge Base root
https://uppsala.support/agent → login
I’m guiessing should just check the nginx config tho?
Ok. Then I’ll do that and put in a feature request? Im sorry I do not have the time to code-support and make a pull request. Thanks for a great software!
Sorry I did not get you right.
Well, you can do that by configuring NGINX.
Another way, use a subdomain for the knowledge base: (like https://kb.uppsala.support/).
https://admin-docs.zammad.org/en/latest/manage/knowledge-base.html?#custom-url
This topic was automatically closed 41 days after the last reply. New replies are no longer allowed.
