Integration with O365
Can I get O365 to access the ticket database in Zammad?
I’m trying to get tickets with a specific Tag in Zammad synched with a Sharepoint, or Planner Table.
Is this possible?
Thanks
Hi @Francescol
you could use Integromat for this.
Option 1
Use the Zammad - Search tickets module:
Search for “Tags:[your tag]”
Option 2
Create a webhook in Zammad and trigger it based on your needs/setting.
Then set up a webhooks module in Integromat
Next
The next module in Integromat would be the Planner or Sharepoint module.
Cheers,
Gijs
This topic was automatically closed 41 days after the last reply. New replies are no longer allowed.
