Hosting a webserver
I’m really a basic level of doing something like website, may i know how to host the zammad?
if it has any guideline from youtube or something, may you send the link?
thank you, appreciated
Documentation with all necessary steps can be found here:
https://docs.zammad.org/en/latest/
But based on your comment I would say you are better off paying for a hosted solution:
appreciated for your answer, and really thank you
I’ve worked with hosting setups before and getting Zammad online usually comes down to choosing the right environment (like Docker, cloud hosting, or a VPS) and then following the installation guide. The official docs are helpful, but for beginners, step-by-step video tutorials or simplified walkthroughs are often easier to follow.
Since you’re starting out, it might also help to think about how hosting ties into the bigger picture of your project. For example, once Zammad is hosted, many people also look at integrating it with their website design so the support system feels seamless to users.
