This guide explains how to change the Zammad logo and create a Zammad package on a GNU/Linux OS for Zammad 6.x.x.
Part 1: Changing the Zammad Logo
Prerequisites:
gitpnpm; Install it with:$ curl -fsSL https://get.pnpm.io/install.sh | sh -
Steps to Change the Logo
Clone the Zammad Repository:
$ git clone https://github.com/zammad/zammad.git -
Navigate to the Logo Directory:
$ cd zammad/public/assets/images/icons -
Replace the Logo:
- Substitute the existing
logo.svgfile with your logo. - Ensure the new logo:
- Is an
.svgfile. - Is named
logo.svg. - Has approximate dimensions of 42px by 36px with 96 DPI (exact size is not critical, but it should be relatively small to save disk space).
- Is an
Build the Assets:
- Navigate back one directory to
zammad/public/assets/images:$ cd .. - Run the following commands to rebuild the assets:
$ pnpm install $ pnpm exec gulp build
After these steps, the
icons.svgfile in thepublic/assets/imagesdirectory will be updated with your new logo. - Navigate back one directory to
Part 2: Creating a Zammad Package with the New Logo
Prerequisites:
- Install the required Ruby version for Zammad as specified in the Gemfile.
- Install RVM.
- Install the correct Ruby version (e.g., 3.2.4) with:
$ rvm install 3.2.4 - Follow the remaining setup steps as described in this repository.
Steps to Create the Package
Set Up a New Project:
- Create a directory for your project and initialize it as a Git repository:
$ mkdir CompanyName-NewLogo $ cd CompanyName-NewLogo $ git init
Add a Template for a New Zammad Package Module:
$ git zammad-new-szpm -
Create the Directory for the Logo:
- Create the directory where the logo will be stored:
$ mkdir -p public/assets/images/ - Copy the updated
icons.svgfile into this directory.
Update the File List:
$ git zammad-update-szpmThe
example-new_project.szpmfile should now look similar to this:{ "name": "CompanyName-NewLogo", "version": "1.0.0", "vendor": "Example GmbH", "license": "MIT", "url": "http://example.com/", "files": [ { "location": "public/assets/images/icons.svg", "permission": 644 } ] }Take the time to personalize the
name,version,vendorandurlfields of theexample-new_project.szpmfile -
Create the Zammad Package:
git zammad-create-zpm 1.0.0 -
Install the Package in Zammad:
- Upload your newly created
company_name-new_logo-1.0.0.zpmfile to Zammad via thePackagessection. - After installing, updating, or uninstalling packages, execute the following commands on your server:
$ zammad run rake zammad:package:post_install $ systemctl restart zammad
Enjoy your new logo in Zammad!
Best,
Skip
