Hello Zammad team,
We would like to share an anonymized production finding and ask you to evaluate whether session handling can be improved for write-heavy environments.
In one of our production systems, PostgreSQL session writes dominate SQL time. The main statement in pg_stat_statements is:
UPDATE "sessions" SET "data" = $1, "updated_at" = $2 WHERE "sessions"."id" = $3
In our workload, this statement accounts for roughly 75% of total SQL execution time. That makes it the clearest database hotspot we found.
Anonymized evidence
UPDATE sessions ...483,718calls98.66M mstotal execution time203.96 msmean execution time73.55%of total SQL time in the sample window
Other expensive patterns exist too, mainly around ticket lists, tags, and taskbars, but session writes are the dominant cost.
We also validated that this is not a missing-index problem:
- primary-key reads are fast,
- common ticket filters already use indexes,
- the issue is the frequency and cost of repeated session writes.
Why we are raising this
Zammad is a Rails application, and Rails supports multiple session storage strategies. For high-concurrency or UI-heavy deployments, PostgreSQL-backed sessions may create unnecessary write amplification.
Because of that, we would like you to evaluate one of these directions:
- move session storage from PostgreSQL to Redis-backed storage, or another non-relational Rails-supported backend,
- if that is not appropriate for the architecture, reduce or eliminate redundant session writes when the session payload has not materially changed.
Why we think this matters
- It would remove a high-frequency write path from the primary database.
- It could reduce latency under heavy UI usage.
- It would lower write pressure on PostgreSQL, which is already handling the ticket workload.
- It would be especially useful for installations with many concurrent agents and many short UI requests.
What we would like you to review
- Can the session store be moved away from PostgreSQL in a safe, supportable way?
- If not, can Zammad avoid writing the session record on every request when nothing material changed?
- Are taskbar, websocket, or notification flows indirectly increasing session churn?
- Is there a better Rails-native approach for sessions in Zammad’s deployment model?
Related community threads
We looked for prior reports before posting and found adjacent discussions, but not an exact match for this write-amplification pattern:
- How is session and user connected?
- Zammad is exhausting resources
- Schedule Clear all session
- Trouble with performance tuning (high reported user count and RAM usage)
These threads suggest sessions are already a known operational topic, but we did not find a prior discussion that specifically addresses sessions writes dominating SQL time in a busy production workload.
Acceptance criteria
- Fewer
UPDATE sessionsstatements in normal usage. - No regression in login, logout, invalidation, or security behavior.
- Lower PostgreSQL write pressure under concurrent operator traffic.
- Clear documentation of the chosen approach and its tradeoffs.
Additional note
We are happy to share more anonymized details if helpful, including:
- aggregated
pg_stat_statementsoutput, EXPLAIN ANALYZEfor the main query patterns,- checkpoint/WAL observations,
- request-path samples with all identifiers removed.
Thank you for considering this.
