Hi, i would edit the login page of zammad, i would insert a button.
When i edit the login.jst.eco and restart zammad, the login page don’t change.
How can i do?
@anon29869905 can you help me?
this is the result of command :
rake aborted!
ActiveRecord::AdapterNotSpecified: ‘development’ database is not configured. Available: [“production”]
with many lines of ruby files
(ex.)
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.5/lib/active_record/connection_adapters/connection_specification.rb:246:in `resolve_symbol_connection’
is there not a simpler method to edit js?
Sorry i wrong the command.
IT WORKS THANK YOU, SOLVED
