I’m using Zammad with Docker. To make it run, I had to adapt a few things and would like to make pull requests which solve the issues I ran into. I’m using GitHub - zammad/zammad-docker-compose: Zammad Docker images for docker-compose which seems not to be deprecated, this refers to Package zammad · GitHub but I can’t find the Dockerfile which was used to create this images. Can you point me to the Repo or the Dockerfile?
Thanks for the reference, I actually faced the issues that I don’t have IPv6 enabled on the system where I’m running it and this causes nginx and the railsserver to fail when trying to bind to the IPv6.
I had some more issues, but as I wrote this post I noticed, that they were caused by my fix, which broke the yaml anchors because a separate volume was defined within the individual container blocks.
An environment variable to disable the IPv6 bindings, would really help.
