Creating tickets without logging
Hi, is it possible to create tickers without logging into the system, with the option to select a ticker group? Because I have seen options for forms but there I can only create one form permanently assigned to one group
Nope, I don’t think so.
Yes there is. Seperat email address for each group. You can can also trigger that via API forms (you’ll have to create on your own) if you need to set objects as well or use different email forms to achieve this.
