Is it possible to massively associate tickets to an article in the knowledge base?
Look for options by macro, trigger or scheduler and neither gives option of something similar
You could workaround this via (undocumented) knowledgebase API if you must.
There’s no other nice UI way to do so. Sorry.
This topic was automatically closed 41 days after the last reply. New replies are no longer allowed.
